Go to Post We need to find the female engineering mentors in FIRST and start having them present/co-present technical conferences at the championships. We need to start showing the girls on the teams that there are female engineering "rock stars" to look up to. - Kims Robot [more]
Unread 30-03-2016, 07:40
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: NT Freezing When Camera Is Unplugged
Originally Posted by dubiousSwain View Post
At competitions, when our camera is unplugged (and sometimes when its plugged in), we get an error on the driverstation that says something along the lines of "Camera not found at the specified ip address". We've noticed a direct correlation between this and a ~6-10 second slowdown of the dashboard refreshing, which we believe can be attributed to network tables. Has anyone else had this problem or can anyone help us fix it? It makes our dashboard basically useless which causes significant problems for our drivers. Thank you.
We experienced the same behavior when the SD card popped out of our Raspberry Pi and failed to boot. Network Table variables and the whole Dashboard GUI become extremely slow to respond.
I have not been able to determine the root cause of this behavior, as the camera read is in it's own loop, and when it's not connected, it does not peg out the CPU utilization or anything weird like I would expect.
I know Joe Ross experienced this issue as well, as I asked him about the issue when I believed it was the mjpg-streamer read that he provided that was causing the issue. I have determined that his team's code was not at fault, but I don't know what is.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
