Go to Post Every single person on the team, read the manual, cover to cover, NO skimming. Do not give the task of knowing the rules to a few people. Do not pass go, do not collect $200, READ THE MANUAL. - RoboChair [more]
Unread 29-03-2016, 21:00
CadenWebb CadenWebb is offline
FRC #4265
CadenWebb is an unknown quantity at this point
Vision Processing in LabVIEW 2016
We are having trouble getting values from our camera in a "hard push" but we are able to see the values during a "soft push."
Unread 30-03-2016, 08:48
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Re: Vision Processing in LabVIEW 2016
I assume by "hard push" you mean "deploy then run as startup" and "soft push" you mean "hit the run button to deploy temporarily". For a "hard push" you need to use networktables and a dashboard, your front panels don't work. I could be of more help if you gave more context.
2015 MAR District Champions
