Go to Post We were all rookies once, and we really have two ways to go about things: either take a page from the powerhouses and emulate their style, or complain about not having anything and risk falling into oblivion. - George A. [more]
Go Back   Chief Delphi > Other > Chit-Chat > Games/Trivia > Fantasy FIRST
  #331   Spotlight this post!
Unread 28-03-2016, 13:15
ttldomination's Avatar
Sunny
Re: [FF]: 2016 Season Long Fantasy FIRST
Those explanations were perfect, and I was able to identify the issues and make the fixes in the automated scoring.
Originally Posted by tindleroot View Post
The gaps of missing data that I'm referring to are missing points for mostly district teams (regionals are almost perfect except for a few instances of missed qualification win points). In the "Raw Picks" tab, Column J (District Points) are shown as 0 for all CHS teams except 1262 and 1610. This problem maintains over all of the districts. Some teams also have ranking points missing from one of their two events, such that they are awarded approximately half points for ranking.
For this one, I found an issue in how the district points calculation was being done. Long story short, the calculation was being done at the district level and not the event level, which lead to issues throughout the sheet.
I have made the appropriate fixes to make sure that the district points are being calculated at the event level and then are being rolled up to the district level.
Looking further, it appears that many district teams are also missing points for robot awards and high scores. 1024 won two robot awards this year and also had the high score at all three of their district points, so if I'm reading the chart correctly their column K on the raw picks sheet should have 45 points but instead has 0.
The issue is that the district system started handing out awards for teams that had qualified for states, but we were not recognizing that award. This ultimately threw and error and caused the teams' scores to go to 0.
Unfortunately, when new awards flow into the system, they're going to cause some havoc until we go in and assign points for them.
In this case, I have given this "award" 0 points, and the issue should now be fixed.
That's the best help I can give at identifying the problem. I am really happy that you guys made the system to simplify scoring throughout the season, and I will keep checking it against First Pick's scores (calculated manually by me) to make sure all points are being awarded properly.
I appreciate you keeping track of your score to help keep the automated system honest, and I appreciate everyone's help in ironing out issues in the system.
Let me know if there are any other concerns,
- Sunny G.
1648: 2013-2014
5283: 2015
  #332   Spotlight this post!
Unread 29-03-2016, 00:43
I'd like to remind everybody that the District Championship drafts are coming up right after Week 5 action (and, in some cases, during that action!). Checking the spreadsheet at https://docs.google.com/spreadsheets...in8/edit#gid=0, we have...
PNW DCMP on Sunday, 7 PM Eastern
Chesapeake DCMP and Indiana DCMP on Monday, 7 PM Eastern
North Carolina DCMP on Tuesday, 7 PM Eastern
Chesapeake and North Carolina still need draft runners.
Now, here's the catch. I could just randomize the order of each draft, same as usual. But, as has been noted, that tends to not give an even spread. I could base off of the current points--but that's even more annoying. So what I'm going to do instead is:
The first draft (PNW) will be randomized. After that, each subsequent draft will move the list "down" one space. That is, first pick in the first draft is now second pick, second is now third, last pick is now first, etc. The only day we're doing two drafts is on Monday--first draft posted takes the first rotation and second draft posted takes the second. What this does (for this size of league) is that everybody will have one pick in every spot on the list.
As a reminder, CMP drafting will happen once the CMP divisions are released. We'll be starting probably the Friday before the event and draft two drafts/day until we're done. Can't do much without the divisions... Draft order for CMP is in order of regular-season fantasy finish.
  #333   Spotlight this post!
Unread 29-03-2016, 01:26
ghostmachine360's Avatar
ghostmachine360 ghostmachine360 is offline
Kyle J. Fender
AKA: Kyle J. Fender
FRC #1002 (CircuitRunners Robotics)
ghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond repute
Whoa, whoa, whoa.
Why are we literally changing the entire structure of the DCMP drafts now? I'm not going to say that we wouldn't agree to the rule changes, if these had been enacted in the beginning of the season. But, we are a week out from the drafts.
The district drafts were more balanced; as shown here in these threads.
MAR: http://www.chiefdelphi.com/forums/sh...d.php?t=140825
NE: http://www.chiefdelphi.com/forums/sh...d.php?t=140894
CHS: http://www.chiefdelphi.com/forums/sh...d.php?t=140909
PNW: http://www.chiefdelphi.com/forums/sh...d.php?t=140889
PCH: http://www.chiefdelphi.com/forums/sh...d.php?t=140944
FiM: http://www.chiefdelphi.com/forums/sh...d.php?t=140723
We should keep the original setup for 2016, and go by the district rankings. As previously stated in the thread, there's a lot of changes to look forward to in terms of execution and the rules for Fantasy FIRST for 2017, as we continue in the future as a more stable/fun part of the Chief Delphi community.
Sincerely,
Rotten Fruit Alliance
Member of the Rotten Fruit Alliance
2013, 2015, & 2016 Fantasy FIRST Elgin Clock Award Winners [RFA]
2015 & 2016 Fantasy FIRST Champions [RFA]
GeorgiaFIRST Advisory Board & District Planning Commitee Member
SPSU Class of 2016: Robotics Engineering Major
GeorgiaFIRST FRC/FTC Emcee, FTC Head Referee, & FRC Referee
2010 CMP FRC Dean's List & 2010 Peachtree DLA Finalist
  #334   Spotlight this post!
Unread 29-03-2016, 01:42
Originally Posted by ghostmachine360 View Post
Whoa, whoa, whoa.
Sincerely,
Just so RFA is aware, RFA was complaining earlier in the season that the drafts were unbalanced due to randomness, and the DCMP and District drafts being unbalanced hurt players. So I was making a change to address that. Or so I thought.
That being said, we will go by district ranking, as shown in the scoring sheet (BTW, I find that links to external documents need to be reposted every few pages just to keep them handy). Ignore my prior post on that topic.
  #335   Spotlight this post!
Unread 29-03-2016, 03:42
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
I'll take responsibility for the post in question: (#86).
I wouldn't say I was complaining, but I was definitely suggesting a different approach to district draft seeding, before said drafts took place. Myself and the others in agreement did not provide a final algorithm or solution at the time. I would be happy to help develop a new approach, based on league feedback in the off-season.
In case anyone is curious, I have similar data to Brennan's on seed order. Ours is not segregated though and includes seed position based on the starting count of FF teams (10), and does not have district drafts separated out (but I could provide that if anyone is interested):
FF Teams	AVG Draft Seed
Rotten Fruit Alliance	4.5
Falcon	                4.68
OrangeJuice	        4.82
Swamp Life	        4.89
The ULCAN	        4.95
Broconnor	        5.17
FIRST Pick	        5.26
The Breakfast Company	5.73
Just looking at district drafts alone, we have variations in the team pool size which make weighting the pick order in certain regions difficult. A 1st seed in Michigan, where we draft 48 teams (from a pool of 400) is definitely not the same as a 1st seed in Indiana where we draft 24 teams (from a pool of 54). I did like the concept of adding onto the serpentine for day two of drafts, but I don't think it solves the underlying issue(s).
In case anyone is interested, here's data which shows averages of just district pick positions for each FF team (across the regions). *Note: A 1st seed in a 24 team draft gets pick positions 1, 16, and 17, for an average pick position of ~11.33, the rest of the numbers were derived similarly (as can be seen on the attached sheet).
(FF Team)(Sum of District Pick Positions)(Average Seeded District Pick Position)
Broconnor	        158.17	19.77
Falcon	                158.83	19.85
Swamp Life	        159.17	19.90
Rotten Fruit Alliance	159.83	19.98
FIRST Pick	        160.50	20.06
OrangeJuice	        160.50	20.06
The ULCAN	        160.50	20.06
The Breakfast Company	162.50	20.31
I'm hoping the individual tracking of drafts (by TBC, OJ, and RFA), as well as the automated scoring system from this season will help us develop new methods next year.
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
  #336   Spotlight this post!
Unread 29-03-2016, 23:22
Kyle J. Fender
AKA: Kyle J. Fender
RFA:
2771 (OUT), 3767 (IN)
  #337   Spotlight this post!
Unread 30-03-2016, 01:04
Quick-ish note on waivers:
I never got that note from TBC on their priority order (unless most of their picks were already out)--but I think we're good to run some. Navid, have you been handling most of those? There's actually some competition this time around (5818 has 3 claims).
  #338   Spotlight this post!
Unread 30-03-2016, 10:27
BrennanB's Avatar
BrennanB BrennanB is offline
TBC is good at getting almost first
AKA: Brennan Bibic
FRC #4476 (W.A.F.F.L.E.S.)
BrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond repute
Whoopsies.
Priority has been sent in PM to Eric
Brennan Bibic - @b_bibic - Eh-Nalysis
10 years of inspiration compilation - W.A.F.F.L.E.S. #4476 YouTube Channel - 64 events and counting!
FRC 2013-2017 (W.A.F.F.L.E.S. Community Robotics #4476) - FLL 2006-2017 (W.A.F.F.L.E.S. #105) - VRC 2010-2013, 2015-2016 (W.A.F.F.L.E.S. #4476)
FRC 2009-2012 (K-Botics #2809)
Fantasy First 2014-2017 (The Breakfast Company) #TBCWin
2014 Dean's List Finalist
"Work until your idols become your rivals."
  #339   Spotlight this post!
Unread 30-03-2016, 11:37
I am up to date on all free trades, except the most recent from Kyle:
RFA:
I need to catch up on are all the waivers that expired last night. Here's the list of original claimants. Just let me know who actually got what, and what they are swapping out:
Originally Posted by Navid Shafa View Post
FF Team	OUT	IN	Event
TBC	?	3802	Hub City
TBC	?	5818	Idaho
ULCAN	?	5050	MI
TBC	?	4639	Lonestar
TBC	?	4904	SVR
TBC	?	2352	Lonestar
This was the last stated waiver priority:
I believe the new waiver priority should be:
Waiver Priority:
OrangeJuice
Falcon
Swamp Life
The ULCAN
Broconnor
FIRST Pick
I processed 48 @ Queen City for Falcon, so Falcon should move to the bottom before handling last night's batch. Other than that, I still need to fill in randoms for all of the Week 4 No-Shows when I get a chance (Thanks Brennan!)...
Randoms to Resolve (Week 4):
FF	Out	Regional
Falcon	698	Colorado Regional
Swamp	2815	Dallas Regional
Falcon	6233	Dallas Regional
OJ	2789	Dallas Regional
Falcon	5873	Dallas Regional
OJ	5947	Finger Lakes Regional
OJ	2502	Iowa Regional
ULCAN	4762	Iowa Regional
FP	5076	North Bay Regional
Founding Member
  #340   Spotlight this post!
Unread 30-03-2016, 11:50
Here's the list:
TBC: 5818 for 5461 (Idaho), 4904 for ???? (SVR), 3802 for 4570 (Hub City), 4639 for ???? (Lone Star), 2352 for ???? (Lone Star)
ULCAN: 5050 for 2851 (Michigan)
Leaves the priority as:
OrangeJuice
SwampLife
Broconnor
First Pick
RFA
Falcon
ULCAN
TBC
  #341   Spotlight this post!
Unread 01-04-2016, 01:26
Here's the list:
OrangeJuice
SwampLife
Broconnor
First Pick
RFA
Falcon
ULCAN
TBC
I am up to date now on all swaps, excluding the TBC waivers above that need attention, and the Week 4 randoms. I'll try and get to those tomorrow, non-robot life has been busy.
Founding Member
  #342   Spotlight this post!
Unread 02-04-2016, 11:51
BrennanB's Avatar
AKA: Brennan Bibic
4639 in, 5416 out (Lone Star)
2352 in, 5427 out (Lone Star)
649 out , 4904 in
  #343   Spotlight this post!
Unread 03-04-2016, 00:23
I really hate to do this to you guys, but PNW DCMP currently only has 7 teams signed up. So, I'm going to bump that one back a day in favor of...
Chesapeake (58 teams) will be run tomorrow, switching positions with PNW. Draft will be up shortly (as in, once I get it set up).
  #344   Spotlight this post!
Unread 03-04-2016, 00:24
I was literally just typing a post like this one suggesting we swap CHS for PNW, since Auburn is still going on tomorrow...
Founding Member
  #345   Spotlight this post!
Unread 03-04-2016, 00:32
That would explain it...
In that case, may as well bump PNW to Tuesday for NC, and put NC on Monday. Gives PNW a little more time to fill in enough for a draft.
