Go to Post And Dave, although I know you have connections, please don't slow the earth's rotation to get more time on the caption contest. ;) - Billfred [more]
Unread 30-03-2016, 12:24
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
Simple LED Light Connection
Rookie Question that I should probably know.. haha
If I want to have just a simple, one color LED strip of lighting, no arduino or such, where is the best place to wire the lights in to turn on when the robot is powered?
Thanks.
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 30-03-2016, 12:27
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: Simple LED Light Connection
If you don't care about having control of them (on/off from roboRIO), you can just wire them in to the PDP.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
If they are 12v LEDs then you can plug them directly into the PDP if you want them on while the robot is on. 5v LEDs can plug into the VRM.
461 Westside Boiler Invasion
45 Technokats
GreyingJay GreyingJay is online now
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
If they can be powered off 5V, then the easiest is to connect them to the VRM, use the 500mA port if it is safe to do so, 2A connection otherwise.
If they are 12V, you can do the same, or wire directly to the PDP as others have said. Don't forget the breaker.
We powered our camera ring light off a solenoid output on the PCM because it can handle 12 volts at up to 500mA. (Note, check if your PCM is set to 12 volts instead of 24 volt output). This way we can turn the light on and off in software.
I bought a set of IKEA DIODER lights hoping to have them installed on the robot - we would just plug them into the PDP - but alas they were too far low on the list of priorities in the pit. Next year!
Unread 30-03-2016, 12:30
Drakxii Drakxii is offline
FRC #4131 (Iron Patriots)
Drakxii is just really niceDrakxii is just really niceDrakxii is just really niceDrakxii is just really niceDrakxii is just really nice
If it's a 12v strip you can just wire up to the pdp, like a motor controller.
If it's 5v you can wire up to the VRM's 5 volt slots.
Any other voltage would not be simple.
Michael D.
Favorite game: Aerial Assist
Least Favorite: Recycle Rush
Pantherbots Mentor - #2582 Lufkin, TX
* Lone Star Regional 2016, 2015 - 3rd place (Semifinals), 2014 - Quarterfinals, 2013 - Quarterfinals (Judges Award)
Iron Patriots Mentor - #4131 Renton, WA
PNW Ranking: 2016 - 18
* Auburn Mountain View District Event 2016 - Semifinals (EE Award)
* Auburn District Event 2016 - Finalists (ID Award)
* PNW Champs 2016 - Quarterfinals
* World Champs 2016 - Carson
Unread 30-03-2016, 12:33
Thanks guys! Thought it was that simple, Just wanted to make sure!
www.valleyx2844.com
Unread 30-03-2016, 12:37
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We use a spike relay
http://www.vexrobotics.com/vexpro/all/217-0220.html
I have heard some teams use their VRM, but id be careful of your current draw.
Unread 30-03-2016, 16:22
aphelps231's Avatar
aphelps231 aphelps231 is offline
Andrew Phelps
FRC #1318 (Issaquah Robotics Society)
aphelps231 has a spectacular aura aboutaphelps231 has a spectacular aura about
If you're using pneumatics and have 12v LEDs, you can plug them into the PCM.
We have two sets of lights for driver signals, one that lights up when a ball is in the robot and one that lights up when the shooter wheels are up to speed.
team1318.org
2016: Flight Director, Alliance/Match Strategy
2015: Mechanical Lead
2013-2014: Fabrication
2016: 2x district finalists, Quality, DCMP Entrepreneurship Awards
2015: 3x district winners, Innovation in Control, Creativity, Team Spirit awards
2014: Galileo Division finalists, PNW District Championship winners, 1x district winners, District Chairman's, Innovation in Control, Entrpreneurship awards
2013: Entrepreneurship award
Unread 30-03-2016, 16:30
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
only if they draw less than 2 amps. I know this from bad experience.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 30-03-2016, 17:24
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
As many said before it depends on the voltage and amperage needed to run the LED strip. What we have been doing is purchasing a LED system such as
http://www.amazon.com/SUPERNIGHT-5-M...zon+led+lights
You can easily cut the wall A/C adapter cord and connect it directly to the PDP using, at most, a 20 amp breaker. You can check the output of the wall adapter to verify it is a 12v output before wiring it into the PDP. This will allow you to use the control module to change colors and run fun flashing LEDs in the pits.. You will need to cover the IR receiver when on the field, or put a connector for easy removal. The control module will retain the last setting. That way in the pits you can select your alliance color and turn off the disco effect.
Just be sure to use some additional insulation. We found out this year that many times the only thing between the LED strip electrical cut/connections is just the 3M adhesive, which isn't always covering as well as it should. We use double sided foam tape, just be aware of over bending the LED strip. There are usually cut points every so often you can wire to bridge tight bends.
Any questions PM me and I can send you detailed pictures.
Good Luck
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
