Go to Post Stratagy drives design, not features. - Wetzel [more]
Unread 03-30-2016, 04:30 PM
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Simple LED Light Connection
Originally Posted by Peyton Yeung View Post
If they are 12v LEDs then you can plug them directly into the PDP if you want them on while the robot is on. 5v LEDs can plug into the VRM.
only if they draw less than 2 amps. I know this from bad experience.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 03-30-2016, 05:24 PM
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
As many said before it depends on the voltage and amperage needed to run the LED strip. What we have been doing is purchasing a LED system such as
http://www.amazon.com/SUPERNIGHT-5-M...zon+led+lights
You can easily cut the wall A/C adapter cord and connect it directly to the PDP using, at most, a 20 amp breaker. You can check the output of the wall adapter to verify it is a 12v output before wiring it into the PDP. This will allow you to use the control module to change colors and run fun flashing LEDs in the pits.. You will need to cover the IR receiver when on the field, or put a connector for easy removal. The control module will retain the last setting. That way in the pits you can select your alliance color and turn off the disco effect.
Just be sure to use some additional insulation. We found out this year that many times the only thing between the LED strip electrical cut/connections is just the 3M adhesive, which isn't always covering as well as it should. We use double sided foam tape, just be aware of over bending the LED strip. There are usually cut points every so often you can wire to bridge tight bends.
Any questions PM me and I can send you detailed pictures.
Good Luck
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Division TBD | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
