Go to Post Supporting a FIRST team, only paying 10 bucks, and possibly winning a segway... what could be better! :) - Tom Bottiglieri [more]
Unread 31-03-2016, 09:36
engunneer's Avatar
engunneer engunneer is online now
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: How are teams with GoPro's connecting them to their monitors?
Originally Posted by Type View Post
We wanted to use a GoPro since it had high quality but we couldn't afford it as a team, but luckily one of our sponsors is letting us borrow their camera . We bought a micro hdmi to HDMI cable, 10 feet long to run down our pole, then we will have another monitor, either a 19" or ~22". The only problem is we need to adapt from HDMI to DVI, which does anyone know of a cheap adapter that works? The cheapest on Amazon is like $30 from what I saw, and I could probably find an actual cable that length from HDMI to DVI.
Also, how are teams keeping their GoPro charged? Are you just plugging it in after the match or do you run a micro usb cable up your pole to charge it?
http://www.monoprice.com/product?p_id=2285 $15 15ft HDMI to DVI Video only.
Unread 31-03-2016, 09:42
Type's Avatar
Type Type is online now
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
Do you know of any like adapter pieces? I just ordered a 10ft micro hdmi to HDMI so I would prefer not to order this, and find something I could plug directly into the monitor. Even if it may cost a little more, less connects to go wrong. Going this path, I would need the Micro HDMI to hdmi, then an HDMI to HDMI, then the HDMI to DVI cable.
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
Unread 31-03-2016, 11:05
nighterfighter nighterfighter is online now
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
We (I) bought a micro HDMI to regular HDMI adapter at Wal-Mart for $40.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 31-03-2016, 11:12
Type's Avatar
Rookie Year: 2016
Thanks for the help. I'll try to figure out the best solution to setting up our camera.
Unread 31-03-2016, 11:17
AKA: Matt B
FRC #1771 (1771)
I was wrong on the price: I found my receipt, it was 19.24 for the adapter, and then $20 for a long HDMI cable (because we forgot to bring any with us)
This was the item we bought:
http://www.walmart.com/ip/GE-miniHDM...apter/48988768
1771- Mentor (2015)
Unread 31-03-2016, 11:33
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
HDMI to DVI adapters are ridiculously cheap at Monoprice
http://www.monoprice.com/product?c_i...seq=1&format=2
Unread 01-04-2016, 09:55
Type's Avatar
Rookie Year: 2016
On another note besides connecting their GoPros, how are teams connecting their monitor to their drivers station if they are using a separate monitor? I'm redesigning my team's driver station and trying to figure out a way to secure it. But make it easy to remove if needed to.
Unread 01-04-2016, 11:29
Background Background is offline
I was there, you just didn't notice
AKA: Gavin
FRC #2067 (Apple pi)
Team Role: Operator
Rookie Year: 2015
Background is an unknown quantity at this point
While probably not the best solution, we have simply put Velcro on the base of the monitor and put it next to the driver station. It has not fallen yet and is easy to remove, but a bit annoying to setup.
Unread 01-04-2016, 11:52
Type's Avatar
Rookie Year: 2016
Okay thank you. My team was considering attaching like a monitor mount but the only thing I don't like about that is that it will take awhile to take the monitor off if we need to. I'm going to see if we can find an easier way.
Unread 01-04-2016, 12:27
AKA: Matt B
FRC #1771 (1771)
Our driver station board is a piece of wood, so we put wood screws through the base of the monitor and attached it that way.
1771- Mentor (2015)
Unread 01-04-2016, 16:32
dsherw00d dsherw00d is offline
FRC #0378
dsherw00d is a jewel in the roughdsherw00d is a jewel in the roughdsherw00d is a jewel in the rough
We used a USB monitor - operating in extended mode off our driver station. Most come with some sort of mount and they are very light. No need for a 2nd power supply and also works if you have an IP camera on the robot. Our USB robot camera went to the DS while the IP robot camera went to the USB monitor (in browser). 2 cameras - no extra programming
http://www.amazon.com/ASUS-MB168B-Po...le+usb+monitor
Unread 01-04-2016, 21:39
Type's Avatar
Rookie Year: 2016
One more question, I know I should probably create a new forum but does anybody know if we could have a coach or human player raise our camera pole for us? We want to keep it down during Auto so 1) it doesn't get hit by a robot's not lined up shot and 2) if they ram the driver's station, it doesn't fall over. It's on a telescoping pole so we will just need to slide it then turn a nob to lock it.
Unread 01-04-2016, 21:42
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
I mean, once it's teleop, your team is free to do whatever they want with your driver station, so long as it stays within the limitations of space. Meaning, they can't raise it past 11' 8".
Also note that G14 and G15 have stipulations that you're allowed to jump the line during Autonomous to save your driver station if it's in danger. It's not a foul, and you don't need the a referee's permission.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 01-04-2016, 22:01
Type's Avatar
Rookie Year: 2016
Okay, thank you. How likely will it be that the camera pole gets hit by a boulder? Has it happened before?
Unread 01-04-2016, 22:04
CalTran's Avatar
Missouri S&T Senior
Dunno if it's happened before, but it's certainly a possibility. Solution? Make sure you have a sufficient mounting system so that it doesn't matter.
