money!
the issue comes down to money at a certain point. off the shelf gears can often be out of our range but delrin gears are usually much cheaper. realistically i'd never consider it without a very wide gear and a very large pitch like maybe 12 or 16.......but only the check book will tell.
| Regional & Division winners, did you shift gears or not? | DougHogg | Technical Discussion | 34 | 02-05-2003 16:10 |
| Helical gears that come with new drill motor | Joe P | Technical Discussion | 4 | 12-01-2003 11:09 |
| Best source for gears? Smallparts? drivetrain advice wanted! | Frank(Aflak) | Technical Discussion | 11 | 10-01-2003 17:22 |
| Need help! What kind of gears are we allowed to use?? | Randy_Ai | Technical Discussion | 3 | 23-01-2002 22:56 |
| replacement gears | joni_m | Technical Discussion | 1 | 22-01-2002 18:01 |
