#15
Re: The REAL chokehold of 2016
G22 ROBOTS may not pin an opponent’s ROBOT for more than five (5) seconds. A ROBOT will be considered pinned until the ROBOTS have separated by at least six (6) feet. The pinning ROBOT(s) must then wait for at least three (3) seconds before attempting to pin the same ROBOT again. Pinning is transitory through other objects. If the pinned ROBOT chases the pinning ROBOT upon retreat, the pinning ROBOT will not be penalized, and the pin will be considered complete. Violation: FOUL. For every five (5) seconds in which the situation is not corrected, FOUL. If extended and egregious, RED CARD There is no FIRST Robotics Competition specific definition of pin, so a general definition applies; “to prevent or stop something from moving.” As a result, contact is not required for pinning to occur. For example, a ROBOT parked right behind an opponent that is on the BATTER could be considered pinning because the dividers on the BATTER and the parked ROBOT prevent the opponent from moving. Generally, pins that exceed fifteen (15) seconds are considered extended and egregious, regardless of a pinning ROBOT’s mobility, however circumstances vary and the assesment is open to REFEREE discretion. Last edited by jdunston94 : 03-31-2016 at 11:29 AM. |
