I've been programmed to love you.
Unread 09-02-2016, 13:10
GRSICP GRSICP is offline
Greta Rauch
FRC #5822 (WolfByte)
GRSICP is an unknown quantity at this point
Best USB Camera for a Rookie Team
Hi Everyone!
I am a programmer on rookie team 5822 WolfByte. We are looking to order a camera or two for our robot.
We are not planning to use GRIP or another type or vision processing because we feel we do not have enough time to figure it out. Because of vision obstruction on the field, we are looking to use a camera to help our drivers see where they are going. We currently are using a Logitech C270 camera and are looking for something with a wider range of vision. What would you suggest?
Thanks for the help!
Greta
Unread 09-02-2016, 13:34
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: Best USB Camera for a Rookie Team
Virtually every out there uses a Microsoft life cam 3000. If you need to buy more, the specs of that are far better than what your bandwidth is. If you need a wide angle camera, I would just find a good lens to put over the camera.
Unread 27-03-2016, 14:04
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Our Microsoft life cam 3000 worked fine during development but largely would not work at 2 regionals when we were on the field. We were eventually told by the FTA that there is a known incompatibility between it and the field management system (FMS). I can't remember if it was java related but we do program in Java. We are using it for human vision (not robot targeting). We had to go out Thursday night of a regional and buy the only Network Camera in stock (a dlink) but had numerous issues again on the field and last I heard we got it going somewhat. It would not work in IE or Chrome. Again I believe FMS + Java were involved in the problem.
Unread 27-03-2016, 14:14
Bkeeneykid's Avatar
AKA: Devin Keeney
Rookie Year: 2015
We also used the Lifecam 3000 and Java on the official FMS with no problems. Our FTA did not mention anything about it. We even used two cameras with code to switch between the two, no problems.
Unread 27-03-2016, 14:16
SagesOfRPG's Avatar
SagesOfRPG SagesOfRPG is offline
Mentor to 5 FLL teams & 1 FRC team
AKA: Wayne Moulton
FRC #5902 (The Wire Clippers)
SagesOfRPG is an unknown quantity at this point
We are using the Microsoft life cam 3000 and it is working well for us.
Any suggestions on how we could rig up a wide angle lens for it?
Unread 27-03-2016, 14:21
de_ de_ is offline
AKA: Dave Edwards
We make a lot of use of the smart dashboard. Do you use it ?
Twice we were out on the field at lunch time with FTAs trying to get the camera to work. They said there was a known incompatibility.
Unread 27-03-2016, 14:29
SagesOfRPG's Avatar
AKA: Wayne Moulton
We used it this weekend at our event. We had a few times where the camera feed dropped, but it was a simple fix. We just had to delete the camera on the JAVA smart dashboard and then add the feed in again.
Unread 31-03-2016, 09:16
Arteezy_RL's Avatar
Arteezy_RL Arteezy_RL is offline
Arteezy_RL
FRC #5980 (East Grand Rapids Robotics)
Team Role: Driver
Rookie Year: 2016
Arteezy_RL is an unknown quantity at this point
We've been using a Logitech C920 it has worked wonders for seeing where we are going and lining up low goal shots. Once we attached a working camera to the front of our ball spitter we were making probably 50% more shots on average.
Unread 31-03-2016, 09:25
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
For those in this topic having no issue with the Microsoft LifeCam HD-3000:
Are you using the Microsoft LifeCam HD-3000 for image recognition (like GRIP), or just so your driver can see?
Unread 31-03-2016, 12:29
ajay16 ajay16 is offline
Ex-Captain/Drive-Coach
FRC #2834 (The Bionic Black Hawks)
ajay16 is an unknown quantity at this point
We are using it as a way for our driver to line up with defenses we want to cross, as well as line up with the low goal. We have a separate Ethernet camera for vision tracking and such. We also have another one of the Microsoft cameras that connects to a raspberry pi for a periscope. They are great cameras that we have been using for the past couple years and we have never had a problem with them. I highly suggest these cameras for any team that wants to throw one on some point in the competition season (this year we ended up drilling through the metal band at the end and putting a few rivets in to secure it). Right now they are around $22 on Amazon so in my opinion they are a great "bang for your buck" camera.
Good luck
Unread 31-03-2016, 13:06
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
I'll 2nd this. We have 2 Logitech C920s and they work great (at one point we had some code issues getting it to show up on our custom dashboard but those seem to be fixed now).
Unread 31-03-2016, 13:16
techhelpbb's Avatar
Good luck
Has your team tried using the Microsoft LifeCam HD-3000 for GRIP or other vision processing on something running Linux (including the RoboRIO)?
I suspect you might view it differently if you did.
FRC11 is using the Logitech C920. We had Microsoft LifeCam VX-3000 years ago, had Linux issues with them, and went to Logitech and PS3 Eye USB cameras along with Axis cameras here and there over the years.
Unread 31-03-2016, 15:19
Back after 4 years off
FRC #5279
We are using the Logitech C270, it is dirt cheap and does the job well. We got out cable cut during practice, and were able to pick up another (and a spare) off the shelf at Walmart for $25 a piece.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 03-04-2016, 10:43
vScourge's Avatar
vScourge vScourge is offline
Videogame Developer
AKA: Adam Pletcher
FRC #4096 (Ctrl-Z)
vScourge will become famous soon enough
We're using three Logitech C920 cameras. One for vision processing with GRIP, two for driver station feeds, all three running through a Raspberry Pi 2.
We struggled a bit during build to find a way to change the exposure settings via script on Arch Linux, but one of our students managed to get an old Logitech utility built and working on the Pi. Without that the image processing camera would have been very difficult to tune.
We also had issues at our first regional getting the two camera feeds to reliably show up on SmartDashboard, using static IPs. In the end we mistakenly had the "mDNS" option still enabled in the SmartDashboard, and the Pi had been forgetting its static IP when cold-booted. After fixing those the feeds were 100% for us.
As far as cameras, the C920 was solid.
