Go to Post Wow! Shipping to Israel?!? It's exciting to have a fan from so far away :D - stens987 [more]
Go Back   Chief Delphi > Competition > District Events
Unread 31-03-2016, 18:39
rwodonnell rwodonnell is offline
AKA: Rick O'Donnell
FRC #2876 (Devilbotz)
rwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to behold
TamperMonkey script to analyze district standings and predict DCMP invitations
I wrote a TamperMonkey script that will run on the district standings page of your choice and make a very crude attempt at identifying those teams that are in, likely in, on the bubble, likely out and out.
It's located here: https://github.com/BHSRobotix/TamperMonkeyScripts
You need the Chrome extension TamperMonkey and the script at the github link above. I set it up for the New England district - if you want to use it elsewhere, you would have to modify the @match parameter on line 7 to match the URL for the district you are interested in.
The biggest reason I am bringing it to public attention is that I have no idea how to do a real statistical analysis, and so my system is very crude. I'd be interested in hearing how to better go about predicting teams' second event score and what the invitation cutoff might be. I've tried to modularize a little so people can just change the right functions but it's likely there is not enough or the right data being passed. I'm interested in feedback.
Unread 31-03-2016, 19:22
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: TamperMonkey script to analyze district standings and predict DCMP invitations
Per a recent (last?) team update, the NE district invite cutoff will be 64 teams.
That will be the top 64 teams by quality points unless a team that's outside of the top 64 gets an invite to champs through other means (district chairmans award). If that happens then I believe the cutoff by rank moves up.
I've done an analysis independently, and determined the cutoff would be around 63 quality pts.
I took the average difference in points scored for all teams who played two events. On average teams improve their first event score by 3pts.
For all teams that haven't played their 2nd event, I just took their first event score plus 3, then sorted all by pts.
This oversimplifies the problem, as some teams will compete in more than two events, the more they play the better they will likely perform. They'll end up pulling available points out of the pool available for teams who haven't played in two events yet... But the above method was a quick way I cane up with determining rank.
http://team2168.org
Unread 01-04-2016, 03:50
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
I think the numbers that you have are not terribly far off for New England.
I've also had a script to do this for some time. It's set up to automatically come up with estimates for any of the districts without any magic numbers. I've previously shared it here: http://www.chiefdelphi.com/forums/sh...3&postcount=13
Appearantly that's not easy to find though so I've put it on github: https://github.com/errorcodexero/standing_predictor I welcome pull requests.
For comparison, here's the output that I get:
Key:
in=will have enough points to make it in
out=won't make it
~in=probably going to have enough points
~out=probably won't have enough points
bubble=could easily go either way
Best-case points to make it to district cmp: 48
Worst-case points to make it to district cmp: 99
Best estimate: 62
{'bubble': 43, 'out': 32, '~in': 38, '~out': 61, 'in': 7}
0	in	1058 - PVC Pirates
1	in	319 - Big Bad Bob
2	in	78 - AIR STRIKE
3	in	4905 - Andromeda One
4	in	230 - Gaelhawks
5	in	5813 - Morpheus
6	in	1831 - Screaming Eagles
7	~in	1768 - Robo Chiefs
8	~in	228 - GUS Robotics
9	~in	176 - Aces High
10	~in	88 - TJ(Squared)
11	~in	4048 - Redshift
12	~in	190 - Gompei and the H.E.R.D.
13	~in	1153 - Robo-Rebels
14	~in	1729 - Team Inconceivable!
15	~in	155 - The Technonuts
16	~in	95 - Grasshoppers
17	~in	4761 - The Robockets
18	~in	131 - C.H.A.O.S.
19	~in	2370 - iBots
20	~in	2648 - Infinite Loop
21	~in	5962 - perSEVERE
22	~in	4909 - Bionics
23	~in	1519 - Mechanical Mayhem
24	~in	2876 - Devilbotz
25	~in	558 - Elm City Robo Squad
26	~in	2064 - The Panther Project
27	~in	1124 - UberBots
28	~in	5846 - Southcoast Corsairs
29	~in	1512 - The Metal Vidsters
30	~in	177 - Bobcat Robotics
31	~in	2067 - Apple Pi
32	~in	885 - THE GREEN TEAM
33	~in	238 - Cruisin' Crusaders
34	~in	125 - NUTRONs
35	~in	195 - CyberKnights
36	bubble	213 - The Dirty Birds
37	~in	6153 - Blue Crew
38	~in	1099 - DiscoTechs
39	~out	5112 - The Gongoliers
40	~out	1277 - The Robotomies
41	~in	839 - Rosie Robotics
42	~out	4055 - NRG4055
43	~out	1735 - Green Reapers
44	~out	246 - Overclocked
45	~in	3930 - SMART Spruce Mountain Area Ro...
46	~out	4151 - SCRAP
47	~out	138 - Entropy
48	~out	2342 - Team Phoenix
49	bubble	6161 - Equilibrium
50	~out	1786 - The Robotics Team
51	~in	4564 - Orange Chaos
52	~in	5687 - The Outliers
53	~in	126 - Gael Force
54	bubble	5686 - Wirecats
55	~out	501 - The PowerKnights
56	~out	4473 - Delta Prime
57	~in	133 - B.E.R.T
58	out	6201 - The Highlanders
59	~out	348 - Norwell Robotics
60	bubble	3461 - Operation PEACCE Robotics
61	~in	175 - Buzz Robotics
62	out	3958 - Schrodinger's Cat
63	out	157 - AZTECHS
64	bubble	2084 - Robots by the C
65	out	4929 - Maroon Monsoon
66	bubble	181 - Birds Of Prey
67	out	2836 - Team Beta
68	bubble	467 - The Colonials
69	out	151 - Tough Techs
70	bubble	5746 - Human Error
71	out	3719 - STEM Whalers
72	out	3205 - Patriots
73	out	4311 - Swampscott Currents
74	out	1721 - Tidal Force
75	out	1071 - Team Max
76	bubble	166 - Chop Shop
77	bubble	1699 - Robocats
78	bubble	3182 - Athena's Warriors
79	out	1350 - The Rambots
80	out	509 - Red Storm
81	out	3323 - Potential Energy
82	out	4097 - Devilbots
83	bubble	2877 - LigerBots
84	out	3236 - TRIFORCE
85	bubble	3609 - Duct Tape Dragons
86	out	4474 - Silver Circuit
87	bubble	3467 - Windham Windup
88	bubble	999 - MechaRAMS
89	bubble	4557 - FullMetal Falcons
90	bubble	58 - The Riot Crew
91	out	178 - The 2nd Law Enforcers
92	bubble	236 - Techno-Ticks
93	out	4176 - Iron Tigers
94	bubble	1100 - The T-Hawks
95	bubble	5556 - Carriagetown Robotics
96	out	4169 - Warrior Robotics
97	bubble	5902 - The Wire Clippers
98	bubble	172 - Northern Force
99	out	5958 - Blue Wave Robotics
100	bubble	3464 - Sim-City
101	bubble	4908 - Duxbury Dragons
102	bubble	2168 - Aluminum Falcons
103	bubble	5752 - Beverly Panthers
104	bubble	716 - Who'sCTEKS
105	bubble	811 - Cardinals
106	bubble	69 - HYPER
107	bubble	6224 - The Saints
108	bubble	5000 - Hammerheads
109	out	1517 - The Lumberjacks
110	out	1474 - Master Link Militia
111	bubble	5422 - Stormgears FRC
112	~out	5856 - Bullbots
113	bubble	121 - Rhode Warriors
114	bubble	237 - Black Magic Robotics
115	bubble	1991 - Dragons
116	bubble	4546 - ShockWave
117	~out	5844 - Phoenix Tech
118	bubble	1073 - The Force Team
119	out	3566 - Gone Fishin'
120	~out	5969 - English Skunkworks
121	bubble	3146 - GRANBY GRUNTS
122	bubble	4906 - The Collective
123	out	5494 - Bizarbots Robotics
124	bubble	2170 - Titanium Tomahawks
125	out	5400 - WARP
126	bubble	3654 - TechTigers
127	out	1307 - Robosaints
128	bubble	571 - Team Paragon
129	bubble	3466 - Vikings Robotics
130	out	97 - Bionic Beef
131	~out	6172 - Team Jupiter
132	~out	2713 - iRaiders
133	out	1247 - Robotics of Kearsarge (ROK)
134	out	1973 - Brighton Burning Tiger
135	~out	5506 - Viking Landers
136	~out	1740 - Ledyard Cyber Colonels
137	~out	5491 - Cognitive Hazard
138	~out	5471 - W.Hi.R.R.
139	~out	5459 - Ipswich TIGERS (Technologicall...
140	~out	3525 - The Nuts & Bolts of Fury
141	~out	5122 - robOTies
142	~out	2079 - 4H ALARM Robotics
143	~out	4572 - BArlow RobAutics
144	~out	3623 - Terror Bots
145	~out	5735 - Control Freaks
146	~out	5563 - Phalanx
147	out	5163 - The Aluminum Warriors
148	~out	3780 - Robot Unicorns
149	~out	4925 - The Resistance
150	~out	1922 - Oz-Ram
151	out	1027 - Project Jabberwocky
152	~out	2785 - Prometheus
153	~out	1289 - Gearheadz
154	~out	3634 - Spark City
155	~out	2262 - Robo-Panthers
156	~out	4628 - Sintian Robotics
157	~out	5633 - Hyde Phoenix
158	~out	4796 - Cyber Dragons
159	~out	1761 - STEAMpunk Tigers
160	~out	173 - RAGE (Robotics And Gadget Engi...
161	~out	4041 - Iron Tigers
162	~out	2423 - The KwarQs
163	~out	4042 - Murphy's Lawyers
164	~out	4555 - Sprocketology
165	~out	1965 - Firebirds
166	~out	3718 - Junkyard Battalion
167	~out	5129 - Digital Devils
168	~out	3451 - The ANOMALY
169	~out	1757 - Wolverines
170	~out	5347 - Gryphons
171	~out	3597 - Robo-Rangers
172	~out	3585 - Rogue Robots of 4-H
173	~out	3104 - The Cyber Rams
174	~out	5265 - Radical Impact
175	~out	4987 - MegaRams
176	~out	4958 - Robocats
177	~out	2523 - Tech Storm
178	~out	5142 - Robo Dominators
179	~out	3555 - Aluminati
180	~out	663 - Robonauts
Unread 01-04-2016, 08:46
AKA: Rick O'Donnell
It's your posts that inspired me to do it with TamperMonkey, and in fact I tried to use your methodology but I struggled to understand the Python code. I only vaguely know the language. I did copy your 5 classifications.
While your posts are awesome and much appreciated, I thought it would be neat to go to the district rankings page and have them automatically do what I wanted right in the browser - the beauty of Grease - er - TamperMonkey. (The original name is so much better!)
My son is taking Python - with your permission, when I get a chance (probably next season at this point) I will, with his help, translate your algorithm into Javascript.
Unread 01-04-2016, 13:23
AKA: Eric
I wonder if there's some way that we could combine our efforts. Putting them inline with the results webpage is definately more elegant than my output. At the same time, I have no idea how to run a TamperMonkey script, and I bet I'm not the only one. I'm not sure what the easiest way is to let people get results is.
How do you run a TamperMonkey script anyway? I tried installing it and got a page that looked IDE-like so I copied your code in but then I wasn't sure what to do next.
I haven't been keeping up on the latest Javascript stuff, so I feel like there's probably some security rules that will prevent this, but is it possible to make a webpage that loads a remote page and then parses it? Can you make an iframe and then mess with its contents? Could this be done with just a normal webpage?
I feel like the less barriers to entry for someone running the script the more useful it will be. For example, I don't know whether anyone besides me has tried to run my script despite it being publicly available for years. I wonder if ultimately the right thing is to put a CGI script together on a server someplace.
What do you think? Either way, feel free to copy the algorithm. And I know it's a little sparse on comments so I'm happy to answer questions about what it's doing.
Unread 02-04-2016, 17:08
AKA: Rick O'Donnell
Once you install a script on your local copy of TamperMonkey, it should run automatically when you go to a page whose URL matches the @match line in the script. So go to the url that the match field says and it should run. If it doesn't, click on the TamperMonkey extension's icon - it should at least indicate that there is a script that can run. Obviously that matching URL is a little specific, and it should be made more general to work for all districts.
I think you're right about this. The TamperMonkey extension is a little work - first you have to install the extension, then you have to go and find matching scripts. It's fun but what would be better is, as you suggest, a web page. There is an API available to pull this data from FRC, so that would probably make the most sense.
