Go to Post We all need to remember to be careful at these competitions. Danger lies in the most unexpected (and comical) places. - Alexander McGee [more]
Unread 21-01-2002, 23:22
PMGRACER's Avatar
PMGRACER PMGRACER is offline
AKA: PAUL GIANNOSA
PMGRACER is on a distinguished road
Re: Gear Boxes
Originally posted by Keithicus
We're gearing the chippy and drill together for our drive, taking the output from the chippy gear, passing it through a larger gear to drive another gear on the drill drive shaft. All gears will be brass. Problem is we've never worked with gears before and I'm not sure how the basics work. Are the gears supposed to turn on a fixed shaft or do you attatch them to a rotating shaft and support that shaft with bearings? If they do slip on a fixed shaft (this would be ideal), what kind of fit do you design for? Do you have to worry about wear? What about thermal expansion? Will the gears bind on the shaft after spinning for a while and getting hot?
Any help would be greatly appreciated.
Keith Sevcik
#920
On a side note, what happens when you burn up a motor? Do the windings actually melt or short or something? Or is it that the magnets are demagnetized from the excessive heat? Do you always have to replace the motor or is it somewhat functional?
Hey Keith. We at Team 27 are also building a Taco/Hole shooter/Shifter setup. We have the Taco geared to an idler which transfers to an output -i call it the pto shaft- the drill motor is geared the same way. We are using Stainless Steel gears and shafts. The idler shafts are fixed, and the gears are bushed, they run freely on the shaft. The Engineer spaced the gears using the pitch dia. + .001/.002 backlash. I have the whole system modeled in AutoCad 14 in 3D, if anyone is interested. Sure would rather use a Chevy 471 though, instead of these torque challenged electric motors!
Racing is an incurable addiction!!
gear boxes BoticsPUNK General Forum 6 24-01-2003 20:35
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
FISHER PRICE GEAR BOXES archiver 1999 2 23-06-2002 22:07
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
