Go to Post We make ourselves better by lifting others and standing on their shoulders, not by knocking them down. - Taylor [more]
Unread 01-04-2016, 13:50
Chris is me's Avatar
AKA: Pinecone
Re: Tape measure climber club
This is a pretty cool club. Are you accepting applications? We might be ready to file ours around Week 7.
Just curious - how many of you are actually using the tape measure as the device supporting the weight of your robot, versus using it just as a hook deployer? My gut says the latter is better.
Unread 01-04-2016, 14:43
Libby K's Avatar
Libby K Libby K is offline
Always a MidKnight Inventor.
FRC #1923 (The MidKnight Inventors)
Rookie Year: 1992
Libby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond repute
We're not doing anything like this for FRC, so I can't speak to these cases, but this fall our two FTC teams discovered that the former does not work well, even for smaller robots. The metal 'tape' ended up breaking off from the spools they were attached to, and the teams switched to a different material after their first two events.
Our two MidKnight Magic teams broke so many tape measures that the Inventors didn't have any left in our shop by the time build season came around. I think they ended up replacing the tapes at least 2 or 3 times an event.
Libby Kamen
Team 1923: The MidKnight Inventors
2006-2009: Founder, Captain, Operator, Regional Champion.
2010-Always: Proud Alumni, Mentor & Drive Coach. 2015 Woodie Flowers Finalist Award.
229: Division By Zero / 4124: Integration by Parts
2010-2013: Clarkson University Mentor for FLL, FTC & FRC
FIRST Partner Associate, United Therapeutics
#TeamUnither | facebook, twitter & instagram | @unitherFIRST
questions? comments? concerns? | twitter: @libbyk | about.me/libbykamen
Unread 01-04-2016, 14:49
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
What width and brand of tape measures were they using? Were the loads purely in tension, or was there significant torsion or shear?
Unread 01-04-2016, 14:54
Drew4564 Drew4564 is offline
It's Tape Measure Time!
FRC #4564 (Orange Chaos)
Team Role: Driver
Drew4564 is an unknown quantity at this point
My team uses the tape measures to support the weight of the robot. While we had an issue with this at the WPI event (a chain of events led to one tape measure twisting and snapping), it has worked just fine. I like using the tape measures as the lifting mechanism because it packaged very well into our robot and only required one CIM for the entire system.
So the tapes actually tore away from the spool they were wound around? After my team's testing during build and first event, we only had one tape measure tear right near the hooks, and never had any issues regarding the spool. I also echo Mr. Lavery's questions.
Team 4564, Orange Chaos
2013-2016: Mechanical Leader, CAD Leader, Driver and Dean's List Finalist (NEDCMP 2015)
2013: Rookie All Star Award and Curie Division 8th Seed Alliance Captain
2014: Gracious Professionalism Award and Innovation in Control Award
2015: Pine Tree #1 Seed and Champion, 2x Innovation in Control Award, #Buttongate Victim
2016: WPI #1 Seed, NEDCMP #1 Seed and Finalists, Excellence in Engineering Award, Creativty Award
Unread 01-04-2016, 15:44
Libby K's Avatar
Rookie Year: 1992
Yes indeed. I'll see if I can dig some pictures of the breaks out of their Engineering Notebook folder, but they would break right before their attachment points on our spools. A pretty clean break straight across the tape measure.
They used Stanley FatMax measures - the widest we could find.
Almost entirely tension. We tried to keep them as free of torsion as we could, but the robot would twist a little bit when it hit the upper churros (FTC field). For our uses it was worth switching to another climber - I'm now a little bit wary of tape measures as pure weight-bearing, but love them as hook-delivery systems.
Libby Kamen
Unread 01-04-2016, 15:56
Bob Potts's Avatar
Bob Potts Bob Potts is offline
Consultant
FRC #4130 (The Blue Devils)
Bob Potts is an unknown quantity at this point
We use the tape measures together to lift the robot. We had one tape tear at the hook once (other held and we did not fall), and both broke at the same time once (we fell , but no damage ). Then we redesigned the hook to grab from the back of the bar. This puts a lot less stress at the hook. Did not have any other issues or failure after that change. The trick is making sure the hook does not kink the tape measure.
2016 Judges Award Kettering 2 District
Alliance #5 Captain 4130 2337 5260 Quarterfinalist
2016 Engineering Inspiration Award Marysville District
Unread 01-04-2016, 16:19
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
How was the tape attached? Did the break occur at the beginning of the lift when the tape was the most unspooled? Were there any extra wraps left on the spool when you started lifting?
We snapped a tape at the hook in testing, but that was thanks a programming error that ran the retract at full power without any voltage ramping. Hook hit the bar at free speed and the shock snapped the tape clean off. Haven't done much more testing, that'll come tomorrow, since I got busy with being sick and work. Should have a good bit of data on our system tomorrow afternoon, though.
Unread 04-04-2016, 22:23
The other Gabe's Avatar
The other Gabe The other Gabe is offline
Too many events, not enough time
AKA: I'm a volunteer now!
no team (2046 Bear Metal Alumn)
The other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud of
got a new member for yall
2471
Do the best you can with what you are given
FRC 2046 2012-2015
Field Scout lead 2014-2015
