Re: Rope for a climber
Just be aware that Spectra and Dyneema are slipperier than "normal" ropes like nylon. Thoroughly strength test your knots to make sure the won't slip.
We used this:
http://www.amazon.com/Braided-diamet...C CV4PTRV7JJ5 It was quite sturdy and held up well. We also used a 400lb test kevlar line that worked, but it frayed way too easily and couldn't be trusted. |
The knot also dramatically reduces the working load of the line. There are certain knots that are better than others from this standpoint.
There are many factors that will affect this result. The linked research on different knots, found that well tied knots of different varieties will reduce strength less than the rule of thumb. The paper didn't mention what the knots were tied to, but my guess is something round. If you attach cordage to a sharp edge, then your resulting system strength is likely to be much less. http://itrsonline.org/wordpress/wp-c...hards.2004.pdf Also the cordage used in the above test is quite a bit different than spectra. Also note that if you redirect the rope's direction with a carabiner, it is going to be under greater strain than it would be in a straight line application. All in all, sand out sharp edges where your rope is attached or contacts a surface and use rope that is much stronger than what you think is needed. Dave |
