Go to Post IT'S LIKE FIRSTmas CAME EARLY THIS YEAR!!! THANKS VEXPro! - akoscielski3 [more]
Unread 01-04-2016, 17:10
Dave_4539 Dave_4539 is offline
AKA: David
FRC #4539 (KAOTICRobotics)
Team Role: Driver
Dave_4539 is an unknown quantity at this point
Multiple batteries?
Our team is doing some promotional stuff for parades this summer and are planning on having a pretty heavy robot. Would creating a series of batteries work? As long as voltage stays at 12, but would amps matter in consideration of the PDP and motors?
"It should work."
Unread 01-04-2016, 17:16
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Multiple batteries?
Don't put the batteries in series; put them in parallel. Putting them in series will increase the voltage.
That is, all of the + leads should connect to one point, and all of the - leads to another.
If doing this, it is best not to mix "good" and "poor" batteries; try to use batteries that have about the same amount of history and health at any given time.
As long as your main breaker is no larger than 120A, you can continue to use the same wires as you use for FRC competition. This means that your combined battery will last longer, not produce greatly increased power.
We use 2 batteries in parallel on our air cannon so that we do not have to do battery changes during a game, and have not had any issues.
Unread 01-04-2016, 17:22
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Yes, but they couldn't be wired in series; they would need to be in parallel. I would say just check the max current for the PDP, all of the fuses, the main breaker, and all other electronics, and don't exceed any of them. Note that this will probably make fuses blow more easily, as they have more current passing through from the battery. This means that if you push a motor, the fuse may blow when it wouldn't with one battery. Also be sure that all wires can handle it, and don't do it at competition!
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 01-04-2016, 17:23
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
if your batteries were in parallel, then they would be providing a nominal 12V, but since the charge level of each battery will be different, it is not recommended. They fuller battery would be trying to charge the weaker one.
A better solution might be to have two parallel battery cables, but only use them for a moment while hot swapping. plug in a fresh battery and unplug the used battery, and you can keep going without a full reboot.
Unread 01-04-2016, 17:36
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
As long as the batteries are reasonably close in AH rating, SOC and general age there is no problem running a parallel battery bank though preferably you charge them as group too. Virtually every diesel powered truck on the road today runs a bank of at least 2 batteries connected parallel and sometimes 3 or 4 batteries on the larger trucks. They are of course permanently connected and charged as a bank, not individually and are replaced as a group with identical batteries.
Unread 01-04-2016, 17:39
It sounds like this is going to be a "parade bot" rather than something meant to play an FRC game. My advice is to design it to use something with a higher capacity, like a large deep cycle marine battery.
Unread 01-04-2016, 17:52
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
If the budget allows, I agree.
If you use a regular marine deep cycle battery, you will have to take greater care to orient the battery with the proper end up. If that is a problem, upgrade to gel cell.
Do not use a car battery - they are engineered for "cold cranking amps", which means that they can put out a massive current for a short period, but cells tend to short out after a number "deep cycles" (more than 50% discharge), which is how it appears you will use them. Marine batteries are designed to be charged on land and discharged while on the water.
Unread 01-04-2016, 23:26
trumpthero786's Avatar
trumpthero786 trumpthero786 is offline
What Part of the Sandwich Are You?
AKA: Humza
FRC #2729 (Storm Robotics)
Team Role: Electrical
Rookie Year: 2015
trumpthero786 will become famous soon enough
Hi. I'm not OP, but I'm curious as to how you would implement these different batteries with FRC electronics. They are 12v just like the FRC batteries but would you just have to find one that has a similar amperage and then connect it as you would a normal battery? Sorry if this my question is silly. I've just never thought about modifications to a normal FRC system am very interested in projects like this.
CLAP CLAP WHOOSH!
2015 - Hatboro Horsham - Quarterfinalist with 272 and 5181 - Entrepreneurship Award
2015 - Seneca - Quarterfinalist with 316 and 5684 - Engineering Inspiration Award
2015 - MAR Championships - 50th Seed - Quarterfinalists with teams 1923 and 11
2016 - Hatboro Horsham - Team Spirit Award
2016 - Seneca - Gracious Professionalism Award
"nice beaver tail"
Unread 02-04-2016, 00:07
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
The amperage rating of a power supply tells you how much current it is capable of supplying. You can can safely replace any DC power supply with another one that has the same voltage rating and equal or higher current rating.
FRC batteries are 12 volts and rated for about 18 amp-hours. A battery capable of 12 volts at 36 amp-hours, for example, will power your robot for twice as long.
Unread 02-04-2016, 12:50
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Provided that you use the same size (or smaller) main breaker (and robustly insulate against any shorts before the main breaker). If you use a larger main breaker, you will need larger main supply wires, and probably a different fuse/breaker panel.
At least twice as long, probably a bit longer, as the ratings are based on fairly slow steady discharge, and our use in FRC is much faster, resulting in fewer net amp-hours. For example, one of the AM batteries is rated:
Originally Posted by ES17-2 Spec Sheet
Nominal Capacity
  • 20 hour rate ( 0.9A to 10.50V ) 18Ah
  • 10 hour rate ( 1.71A to 10.50V ) 17.1Ah
  • 5 hour rate ( 3.06A to 10.20V ) 15.3Ah
  • 1C ( 18A to 9.60V ) 9.6Ah
  • 3C ( 54A to 9.60V ) 6.3Ah
In typical FRC usage of 54A, the battery can only provide 1/3 as many amp hours as it can at around 1A. In a pushing contest, that number probably drops by about another factor of three.
