Go to Post A good teacher always needs to be a good student - Redhead Jokes [more]
Unread 01-04-2016, 17:16
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Safety Inspection vs Inspection?
Originally Posted by protoserge View Post
The inspection process should not be different at any events.
As noted before, robots do not need to pass inspection to play practice matches.
They do need to be safe in order to practice, and that is where the concept of the Safety Inspection comes from
Section 5.5.2 of the game manual..
ROBOTS are permitted to participate in scheduled Practice MATCHES prior to passing Inspection. However, the FIRST Technical Advisor (FTA), LRI or Head REFEREE may determine at any time that the ROBOT is unsafe, per Section 3 (3.4.1 Safety Rules), and may prohibit further participation in Practice MATCHES until the condition is corrected and the ROBOT passes Inspection.
How a robot is determined to be safe does vary between events and is usually driven by a discussion between the LRI and FTA before practice matches and communicated to the teams during the driver meeting.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 02-04-2016, 10:33
scottgoering scottgoering is offline
FTA since 2013
FRC #0935
scottgoering is on a distinguished road
The assumption generally is that a robot is safe, unless deemed otherwise. There's no concept or definition of a Safety Inspection in the rules and is not something that is checked prior to participating in practice matches.
The exception to all of the above is the Filler Line. You must have fully passed inspection in order to participate in practice matches via the Filler Line.
