Go to Post We are customers to FIRST. In that comes expectations. I don't want to hear another, "You should be grateful for everything FIRST does" nonsense when FIRST royally screws up. - MikeDubreuil [more]
Unread 01-04-2016, 17:52
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Multiple batteries?
Originally Posted by Alan Anderson View Post
It sounds like this is going to be a "parade bot" rather than something meant to play an FRC game. My advice is to design it to use something with a higher capacity, like a large deep cycle marine battery.
If the budget allows, I agree.
If you use a regular marine deep cycle battery, you will have to take greater care to orient the battery with the proper end up. If that is a problem, upgrade to gel cell.
Do not use a car battery - they are engineered for "cold cranking amps", which means that they can put out a massive current for a short period, but cells tend to short out after a number "deep cycles" (more than 50% discharge), which is how it appears you will use them. Marine batteries are designed to be charged on land and discharged while on the water.
