Go to Post It's far easier to find ambiguity in the rules than to write them. - MikeE [more]
Unread 01-04-2016, 21:40
NathanZhu NathanZhu is offline
FRC #2415
NathanZhu is an unknown quantity at this point
Robot lag?
So recently we discovered that whenever we tried to drive our robot, there was some lag time between the time we moved the joystick to the time the robot moved. Also, the robot continued to move even when we were not holding the joystick down. There was no change in code and we did not do anything different to the robot. Any ideas?
Unread 01-04-2016, 21:56
SndMndBdy SndMndBdy is offline
FRC #3419
SndMndBdy is on a distinguished road
Re: Robot lag?
Try checking a few things:
1. On the driver station, check your robot CPU usage. If it's high (over 30%) something funny might be going on with your code.
2. Check task manager for your computer's CPU usage. If it's high, check to make sure there are no other unnecessary process running on your computer.
3. Check your network connection. Look in the diagnostics tab of the driver station and look for packet loss and round trip time (they might not be callled exactly that, but something like that). If they are high, that could be a problem. Switch to a tethered connection (USB or network cable) and see if that's the problem.
4. Check that your joystick is not broken. You can see some raw diagnostics about the joystick on the USB tab of the driver station.
Unread 01-04-2016, 22:15
KosmicKhaos's Avatar
KosmicKhaos KosmicKhaos is offline
Calm Cool Collected
AKA: Andrew Thompson
FRC #1126 (SparX)
Rookie Year: 2015
KosmicKhaos has a spectacular aura aboutKosmicKhaos has a spectacular aura about
Re: Robot lag?
As far as the robot moving while the joystick is not being moved you may want to check the trims on your joysticks if they have them. Play around with the X and Y trims. If the problem still persists you may want to try setting a dead band in the code.
2016 Greater Pittsburgh Regional Winner (With 5406 and 1559) | Finger Lakes Regional Semi-finalist
2015 Greater Pittsburgh Regional Quarter-finalist | Finger Lakes Regional Semi-finalist
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Are you using multithreading?
Unread 01-04-2016, 22:48
trumpthero786's Avatar
trumpthero786 trumpthero786 is offline
What Part of the Sandwich Are You?
AKA: Humza
FRC #2729 (Storm Robotics)
Team Role: Electrical
Rookie Year: 2015
trumpthero786 will become famous soon enough
Re: Robot lag?
We had this issue when some vision code was implemented, but not refined or tested, causing a good 1 to 2 second lag. Like others have said, I would look for something that is using more resources than it should be. Or it's just a network/wireless issue.
CLAP CLAP WHOOSH!
2015 - Hatboro Horsham - Quarterfinalist with 272 and 5181 - Entrepreneurship Award
2015 - Seneca - Quarterfinalist with 316 and 5684 - Engineering Inspiration Award
2015 - MAR Championships - 50th Seed - Quarterfinalists with teams 1923 and 11
2016 - Hatboro Horsham - Team Spirit Award
2016 - Seneca - Gracious Professionalism Award
"nice beaver tail"
