Go to Post That is the ultimate "dream match" that I long to see. If not during the season, maybe we will see it at IRI. :) . - dlavery [more]
Unread 01-04-2016, 13:23
TylerS's Avatar
TylerS TylerS is offline
AKA: Tyler Stark
FRC #1747 (Harrison Boiler Robotics)
TylerS will become famous soon enough
Hooks for climbing
Is anyone familiar with any inexpensive hooks that can lock onto the hanging bar with no actuation?
Or better yet if you have seen or are willing to share a clever and simple design for one that can be made in house.
Purdue University 2019 - Aerospace Engineering
2016 - Team 1747 - Design & Build Mentor
2015 - Team 303 - Coach/Build Captain
2014 - Team 303 - Build Captain
2013 - Team 303 - Driver
2012 - Team 303 - Programming Leader
Unread 01-04-2016, 14:08
Chris is me's Avatar
AKA: Pinecone
Re: Hooks for climbing
Two question mark shaped plates cut out of ~1/8" aluminum plate, bolted together with several standoffs. This allows for a passive "over the top" hang pretty easily without any actuation or anything like that, and you can tie your hanger string to the standoffs.
Unread 01-04-2016, 14:29
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Try searching for snap hooks and carabiners.
Here's an example. At 70# working load, you'd need two to lift most robots, but you'd probably want that for stability purposes anyway.
Unread 01-04-2016, 14:31
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
A strong carabiner would work.
We used part of an old AM14U chassis front plate as our hook.
Unread 01-04-2016, 15:25
emeraldstorm's Avatar
emeraldstorm emeraldstorm is offline
#tsimfd
AKA: Quaid Trudell
FRC #5203 (Chaos Inhibitors)
Rookie Year: 2015
emeraldstorm is an unknown quantity at this point
The design I was going with uses ATV tow hooks, that will be machined by a sponsor to screw onto the threads of our pneumatic cylinders. The model we're machining:
http://www.amazon.com/22411-Hardware...=curt+tow+hook
We're unsure how much the rod will rotate in the cylinder, but the weight of the tow hook should keep both hooks in the same direction.
Unread 01-04-2016, 15:33
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
We have these from 2013. When the cylinder fired, the bar pushed the hook bottom causing them to rotate. Once latched they can't unlatch without some human assistance. Just like Chris mentioned.
461 Westside Boiler Invasion
45 Technokats
Unread 01-04-2016, 16:14
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
ours is just a plasma cut question mark made out of .125 5052 aluminum plate.
It is about 5/8 wide where we attach the kevlar cable and about 1 inch wide where it goes over the bar. We only use one. Works like a charm.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 01-04-2016, 17:31
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
If you do have rotation, a piece of flat bar between the two hooks mounted to the pre-drilled holes in the hooks would keep them oriented in the same direction. This bar could be plastic or fiberglass; it doesn't have to bear a significant load.
Unread 01-04-2016, 17:35
dkavanagh dkavanagh is offline
FRC #0578 (Red Raider Robotics)
Rookie Year: 2015
dkavanagh is an unknown quantity at this point
We bent our own hook(s) out of 1/4" cold rolled steel rod. It was plenty strong enough when cold formed. If you heat it to bend it, it becomes soft and won't hold up.
Unread 01-04-2016, 18:07
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Here's what we used Obviously we ground down the sharp points. They are fantastic and cheap too!!
http://www.amazon.com/Drop-Rig-Ball-...ds=shark+hooks
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 01-04-2016, 20:18
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Surely you joust jest?
Unread 01-04-2016, 21:06
NathanStro's Avatar
NathanStro NathanStro is offline
Webmaster for 5980
AKA: Nathan Strodtbeck
FRC #5980 (East Grand Rapids Robotics)
Team Role: Webmaster
Rookie Year: 2016
NathanStro is an unknown quantity at this point
Let me star this by saying team 5980 has never had any problems with their hooks. Team 5980 uses belay hooks that a climber would us. We bought big ones at Lowe's for 2 dollars a piece. We cut them in half and they fit perfectly on the bar. Shoved them into our scissor lift and they work great. Good luck with your search.
Unread 01-04-2016, 22:00
Arteezy_RL's Avatar
Arteezy_RL Arteezy_RL is offline
Arteezy_RL
Team Role: Driver
Rookie Year: 2016
Arteezy_RL is an unknown quantity at this point
Here is our hanging mechanism. We just bought some assorted carabiners from Lowes or Walmart then just cut them to fit. If you are using more of a winch you might want to use something else, not sure.
