Go to Post I still have 3 good ligaments left and 2 events, so I should be fine :rolleyes: - esquared [more]
Unread 31-03-2016, 21:43
ollien ollien is offline
FRC #5202
ollien is just really niceollien is just really niceollien is just really niceollien is just really nice
Safety Inspection vs Inspection?
I realized this after we left practice day at our event. We had gotten inspected, but I keep hearing something about "safety inspection." What is this? Do we need to do something else before we're allowed to play a match? Perhaps I'm blind, but I don't see anything in the manual.
Thank you!
Unread 31-03-2016, 21:46
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Safety Inspection vs Inspection?
It's usually something else for teams who haven't passed inspection who want to use the field for practice to make sure they don't damage other robots or the field.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
FRC #5202
So in other words, if we've passed inspection, we're good?
Unread 31-03-2016, 21:47
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Yes.
Kevin Li
596 - Sciclones
FRC #5202
Thank you!
Unread 31-03-2016, 21:59
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
The UL safety advisers will also check out your pit for safety, but there is no formal safety inspection beyond the safety elements of the normal robot inspection.
Unread 31-03-2016, 22:51
DonRotolo's Avatar
Back to humble
FRC #0832
In terms of a Robot Inspector, the "Safety Inspection" allows you to participate in practice matches. The RI will give a brief check for any major safety issues, such as no bumpers, grossly miswired power, chainsaws and axes, that sort of stuff. That is typically done at weigh-in, and takes a few tens of seconds only. Your safety inspection is completed when you get your inspection sticker, and your full inspection is when you get your colored dot and the inspectors initials on the sticker.
Unread 01-04-2016, 14:00
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
1) There is no such thing in the manual about "safety inspection". the robot has either passed Inspection, or not. 5.5.2 allows for uninspected robots to play in practice matches. However, an LRI or Head Ref can determine that a robot is unsafe and disallow the robot from further participation until it has passed inspection.
2) There are times when RI's hang out in the Que giving robots a quick once-over before they get on the field. They are primarily looking for secured batteries, bumpers, etc. You might consider that a "safety inspection".
3) Even if you have passed inspection (and multiple inspections), that doesn't prevent a RI from finding something that has to be fixed.
Unread 01-04-2016, 15:27
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Adding to the above points...
There's also a practice at certain events where you get the white part of the inspection sticker after you pass the first half page or so of the inspection check list. This is analogous to "safety inspection" as described in this thread. It's the gross check on obvious hazards. Then, after the full checklist is complete, you sign the sheet, get the colored dot, and the white part gets initialed. That means you've passed initial inspection, makes you eligible to compete in qualification and playoff matches, and allows you to enter the filler line for practice matches.
It's not documented anywhere, but that's been my experience with it. Some events do this, some do not. Your mileage and experience may vary.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 01-04-2016, 16:31
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
The inspection process should not be different at any events.
As noted before, robots do not need to pass inspection to play practice matches.
Unread 01-04-2016, 17:05
DonRotolo's Avatar
Back to humble
FRC #0832
I disagree. The inspection process should be completely different at each event. In fact, it should be dramatically different even from inspector to inspector!
(Today is 4/1/16 FWIW)
Unread 01-04-2016, 17:16
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
They do need to be safe in order to practice, and that is where the concept of the Safety Inspection comes from
Section 5.5.2 of the game manual..
ROBOTS are permitted to participate in scheduled Practice MATCHES prior to passing Inspection. However, the FIRST Technical Advisor (FTA), LRI or Head REFEREE may determine at any time that the ROBOT is unsafe, per Section 3 (3.4.1 Safety Rules), and may prohibit further participation in Practice MATCHES until the condition is corrected and the ROBOT passes Inspection.
How a robot is determined to be safe does vary between events and is usually driven by a discussion between the LRI and FTA before practice matches and communicated to the teams during the driver meeting.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 02-04-2016, 10:33
scottgoering scottgoering is offline
FTA since 2013
FRC #0935
scottgoering is on a distinguished road
The assumption generally is that a robot is safe, unless deemed otherwise. There's no concept or definition of a Safety Inspection in the rules and is not something that is checked prior to participating in practice matches.
The exception to all of the above is the Filler Line. You must have fully passed inspection in order to participate in practice matches via the Filler Line.
Unread 05-04-2016, 20:02
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
No chainsaws or axes!? darnit..... this means we need to rethink our DCMP strategy
