Go to Post STEM is the new cool, STEM is the new fun, but nobody said STEM is the new easy. - Taylor [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 03-04-2016, 09:52
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Looking for Last Minute Fixes on a Possible "Comm" Error
If not too late talk to the control specialist onsite, and review the driver station logs with him/her.
The sooner we get behind schedule, the more time we have to catch up.
Unread 03-04-2016, 10:07
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
This could be a battery issue. The roboRio has a brownout mode where it will shut down the motors to preserve communications when the voltage gets below 6.8 V. If your using some old or not fully charged batteries you may be running into this. The battery voltage then recovers a bit later with no motor current draws and you pickup some control.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 03-04-2016, 10:16
messer5740's Avatar
messer5740 messer5740 is online now
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Just a tip-
Secure all ethernet/ wire connections and restart the driver station program before EVERY MATCH. Also, cycle batteries to ensure your voltage is up.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 03-04-2016, 10:35
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #1736 (Robot Casserole)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
Originally Posted by Kevin Sevcik View Post
If you physically have the Driver Station available, you can pull up the Driver Station Log Viewer from the start menu and look through the logs. Help on all that here. I'm about to hit the sack, so I won't be more help tonight.
We had a couple qual matches where we were dropping close to 100% of packets at times confirmed with the driver station logs. Most other matches, packet loss was very low. Interestingly enough, we were competing in the same match as above, though I can't say if this was one of the matches we had problems in also. I know 2338 had some similar issues too.
