Go to Post At the Chesapeake Regional, we will be weighing any team that brings in a kitchen sink (or other major appliances) or an extra robot... - RoboMom [more]
Unread 03-04-2016, 15:37
loonmoon loonmoon is offline
FRC #3244
loonmoon is an unknown quantity at this point
Re: Spy box rules
yep it's just signaling. I the only thing reaching out is my arms and non-electronic objects that I'll be holding.
Unread 03-04-2016, 16:31
Aura_ Aura_ is offline
Aura_ is infamous around these partsAura_ is infamous around these partsAura_ is infamous around these partsAura_ is infamous around these partsAura_ is infamous around these partsAura_ is infamous around these partsAura_ is infamous around these parts
Re: Spy box rules
I believe you can break the paying field plain because of the Q&A about the baguette and the leg of lamb.
Unread 03-04-2016, 16:56
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: Spy box rules
Literally all that q&a clarified was that an unpowered flashlight is functionally equivalent to a baguette. You still can't stick a limb into the field during a match, regardless of what's your holding.
Academic Student (Forever)
Unread 03-04-2016, 18:10
Re: Spy box rules
Originally Posted by CalTran View Post
You still can't stuck a limb into the field during a match,....
...so a leg of lamb is right out.
Unread 03-04-2016, 19:45
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Spy box rules
G4 prevents a Drive Team member from extending any part of the body in to the Field.
G37 says the Drive Team may not contact anything outside their starting area (castle, spy box).
So, as long as you are not holding anything, you can extend outside the starting area, as long as you are not extending into the field.
One possible interpretation of G38 is: If you are holding something, if that something leaves your starting area, then you are contacting something outside your starting area, and are in violation of G37. This would prevent you from extending mutton into the field.
Unread 04-04-2016, 08:29
Nikil Ragav Nikil Ragav is offline
FRC #5566
Nikil Ragav is an unknown quantity at this point
Re: Spy box rules
Are you allowed to use any radio or some type of audio communication device to communicate with the drivers/coach?
Unread 04-04-2016, 08:46
Edxu's Avatar
Edxu Edxu is offline
Strategy/Scouting Mentor
AKA: Edwin Xu
FRC #4476 (W.A.F.F.L.E.S Robotics)
Edxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud of
Re: Spy box rules
No. You cannot have any powered device to communicate or signal the drive team.
2013 FRC World Champions (1477, 1241, 610)
Queens University Computing Class of 2020
2013-2016: Team 610
2017-????: Team 4476
