Go to Post Needless to say, lots of smoke came out, and I debated using its terrible smell as a deterrent. - Snapshot [more]
Unread 04-04-2016, 00:01
BotDesigner's Avatar
BotDesigner BotDesigner is offline
Design/CAD/Strategy/TeamManagement
AKA: David Gedney
FRC #4418 (Team Impulse)
BotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud of
Re: Flipping Rule
Here's something to consider:
Were you, in any way, shape, or form, blocking access to the batter, as any "reasonably astute" observer should be able to tell? Note that I'm not asking about the initial tip. To put it another way: Would your opponent need to move/contact you to have a free shot at the batter?
If the answer is "Yes", then G11 is unlikely to apply, because the opposing robots are trying to accomplish a game objective by running for the batter, and your robot just happens to be in the way. And because the GDC has specifically stated that disabled/tipped/otherwise non-functional robots are NOT exempt from fouls (presumably to thwart a couple of possible strategies aimed at breaking rules to block massive points--I won't go into those here, but one may be fairly obvious from the location I'm currently considering), then it becomes a case where the refs have no choice.
Your BEST BET is to, if such a case happens, head for the question box and have this discussion with the head ref.
We didn't flip ourselves in front of the batter, they flipped us in front of the batter. So even if we were in front of the batter in the last 20 seconds it was because we were forced to be there. G11 would not apply if we lost comms directly in front of the batter. By the yellow card it was acknowledged that the flip was intentional (or could have been avoided) and therefore it was their fault that we were in front of the batter. Their fault, their penalty.
