Go to Post Just fill your wheels with depleted uranium - EmileH [more]
Unread 04-04-2016, 09:54
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Analog Pressure Sensor Labview Programming
Originally Posted by s5511 View Post
I used the Get Voltage.Vi and plugged the output into the Volts to PSI.vi, and printed that value, but now I am getting values between -.5 and -.3... Is there anything that I could be doing wrong? The yellow wire on the sensor is plugged into the Signal port on the roboRIO's Analog 0 port.
You're getting negative voltages? That doesn't seem right. There is no way you should be getting negative voltages from the RoboRIO.
Here is a link to the VI that we're using to convert the voltage to a pressure.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
