Go to Post "The devil" isn't in the details... The devil is having a loud house party with lots of other devils and demons in the details. And laughing, and laughing... - pfreivald [more]
Unread 01-04-2016, 08:34
s5511's Avatar
s5511 s5511 is offline
FRC #5511
s5511 is an unknown quantity at this point
Exclamation Analog Pressure Sensor Labview Programming
We are trying to use the Analog Pressure sensor to display the pressure of the pneumatic system of the robot during the match. We are using LabVIEW robot code, and the sensor is plugged into the Analog Ports on the roboRIO. We used the AI Open.vi and the AI Get Value.VI in LabVIEW to retrieve the data. However, it is returning values between 398-402. How do we fix this issue and get the correct value from the sensor?
Thanks!
Unread 01-04-2016, 08:47
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: Analog Pressure Sensor Labview Programming
Can you post a link to which sensor you are using? Also, are you sure the analog sensor is wired up correctly?
Unread 01-04-2016, 09:20
Pi Fighter's Avatar
Pi Fighter Pi Fighter is offline
Insert Monty Python Reference Here
AKA: Trevor
FRC #1718 (Fighting Pi)
Pi Fighter has a spectacular aura aboutPi Fighter has a spectacular aura about
If you're using the REV Robotics Analog Pressure Sensor, their datasheet has an equation to convert the voltage measured by the analog channel to the pressure measured by the sensor.
Datasheet: http://www.revrobotics.com/wp-content/uploads/2015/11/REV-11-1107-DS-00.pdf
I don't have access to an FRC version of LabVIEW today, but I made a quick subVI that calculates the pressure from a given voltage (The VI is just the equation in the datasheet).
You should be able to use the AI Open.vi in begin to name the reference, then use the AI Get Raw Voltage.vi in teleop (or autonomous) and wire that value right to the subVI to get the pressure.
Hope this helps!
Unread 03-04-2016, 07:34
s5511's Avatar
FRC #5511
I used the Get Voltage.Vi and plugged the output into the Volts to PSI.vi, and printed that value, but now I am getting values between -.5 and -.3... Is there anything that I could be doing wrong? The yellow wire on the sensor is plugged into the Signal port on the roboRIO's Analog 0 port.
Unread 03-04-2016, 10:21
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
What are the three colors of the wire? It could be possible that the wire is flipped the wrong way in the RoboRIO.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
Unread 04-04-2016, 09:54
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
You're getting negative voltages? That doesn't seem right. There is no way you should be getting negative voltages from the RoboRIO.
Here is a link to the VI that we're using to convert the voltage to a pressure.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
