| View Poll Results: Are You Tracking The Goal To Help Shoot | |||
| Yes - And It Works! |
133 | 49.63% |
| Kinda - We Are Working On It! |
104 | 38.81% |
| Nope - We Are Not Using A Camera |
31 | 11.57% |
| Voters: 268. You may not vote on this poll | |||
#31
Re: Are You Using A Camera To Align Their Shooter?
I'm curious if your feedback is based on the contents of these documents, or on the ability to find them? Greg McKaskle |
#32
I'm Erik's programming mentor on 2877. The documentation problems weren't so serious that we couldn't get our Vision work. In fact, we just came back from the WPI District event and we had the only 20 point autonomous there. We didn't miss a single vision-assisted goal the entire weekend, when our drive train was actually working. The lack of documentation is for things like annotating an image (the imaqOverlay calls just didn't work for us), or what the "float" pixel value means in the imaqDraw family of calls. See my (essentially) unanswered questions at: https://decibel.ni.com/content/thread/43729?tstart=0. Also, although we almost certainly had the best Vision at WPI, doing it on the RoboRio is slow, so we'll probably go for an on-board co-processor next year. And it's doubtful if the NI libraries would be available for any of the co-processors we'd consider. |
#33
The big thing I want to emphasize with your robot if you are using vision is the closer you are to the target the less disruptive light can be in the way and the more accurate vision can be.
#34
We're using GRIP, and competed this week at orlando. No problems reported from the driver. In fact, the robot made every autonomous shot it took, so it was working pretty well. Let me know if you have any questions.
#35
We use two USB webcams, one in the RIO and one in the Kangaroo. The Kangaroo has GRIP running on it and is set to broadcast the contours out to NetworkTables. From there our robot program (C++) on the RIO takes the numbers and adjusts our robot's drive motors to center the robot side to side. We then use a potentiometer on our shooter arm to adjust it to the right angle and then it fires. We have been making about 24/25 shots at the batter, and 20/25 from the defenses. Our second camera in the RIO is so the drivers have some human vision on the field, because we haven't figured out how to publish video from the kangaroo to the driverstation. We plan to get the robot shooting in auto during this week and hope to do good at 10,000 lakes in a few days! |
#36
We didn't notice a difference between vision when we were close vs far at either of our two regionals. With correct camera exposure settings and tuned vision filtering, you can completely eliminate overhead lighting and tower LEDs from your image.
#37
Use the "Publish Video" operation in GRIP, and the GRIP SmartDashboard extension with the IP set to the Kangaroo's IP address.
