Go to Post I decided I would keep coming and it just kept getting more and more fun. By the time build season started going I couldn't have quit if I wanted to ^_^ - Mr. Pockets [more]
Unread 04-04-2016, 07:52
joeojazz joeojazz is offline
FRC #5712
joeojazz is an unknown quantity at this point
Re: pic: Simple hook delivery system
How did you use the rubber band like a crossbow if it was inside of the pneumatic cylinder. Also could you fit under the low bar with it?
Unread 04-04-2016, 08:09
connoc1 connoc1 is offline
FRC #2084 (Robots by the C)
connoc1 is an unknown quantity at this point
What I believe they did was use that red stick thing to push back an elastic band (probably surgical tubing), and then used the pneumatic cylinder to hold back the elastic band and keep it there until it was quickly released by actuating the cylinder.
FRC 2084, Robots by the C
Last edited by connoc1 : 04-04-2016 at 14:03. Reason: CD censored a word that in that case shouldn't have been censored
Unread 04-04-2016, 09:49
Chris is me's Avatar
AKA: Pinecone
Originally Posted by BotDesigner View Post
What is terrifying about this is that it could be cheesecaked on almost all stronhold robots. I bet cheesecaked scalers like this are going to be a familiar sight come Champs.
I strongly suspect you haven't tried to add a hanging mechanism to a robot that wasn't designed for one within a 6 hour window before! It's quite difficult. Getting the hook onto the bar is the easy part. Dropping in a winch, ensuring that winch either pulls from the robot's CG or from multiple points on the robot, keeping the robot level on its way up, and programming make this a nontrivial task. I'm sure it'll be done once or twice, but this won't be commonplace, particularly for short robots.
The other reason this won't be seen that often is that your second pick this year actually is really valuable and needs to play the game well, whereas in 2015 you could pick a robot that was a lot worse at playing the game in exchange for a robot that is easy to cheesecake.
Unread 04-04-2016, 11:29
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
The winch, I think, is the easy part: http://www.gearwrench.com/MagentoSha..._FRNT_MAIN.jpg
I agree that the longest part of the cheesecaking process would be locating it on the robot to align with the CG, though.
Unread 04-04-2016, 12:51
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
We'll already have a motor/winch attached to the cheesecake version at champs. We had a BAG motor with a 90:1 reduction attached to the spare mechanism we made at Vegas and the entire thing (hook+launcher+winch) weighed in at 3.5 lbs. The BAG motor takes about 6-8 seconds to winch up and scale.
Not shown in the original picture is an eye bolt that goes through the end of the launching tube. If the rope for climbing is run through that fixed location near the top of the robot, there aren't issues with CG.
I honestly don't think it takes more than half an hour to install a mechanism like this on a robot and get it to work. It's tough to do at a regional level since all three teams begin playing back to back elimination matches immediately, but at championships you have a bit more time and a 4th robot.
Unread 04-04-2016, 13:25
FRC_498's Avatar
FRC_498 FRC_498 is offline
Lead Mentor - Drive Coach
AKA: Adam Shroyer
FRC #0498 (Cobra Commanders)
FRC_498 is a jewel in the roughFRC_498 is a jewel in the roughFRC_498 is a jewel in the rough
We were watching the Las Vegas Regional this past weekend and were wondering how you did that! Congrats on the win and designing an awesome simple yet effective climber! P.S. we might need to borrow that this weekend at AZ West...:
Unread 04-04-2016, 22:06
fiona.crush1011 fiona.crush1011 is offline
AKA: Fiona Hanlon
FRC #1011 (CRUSH 1011)
fiona.crush1011 is an unknown quantity at this point
If you miss, can you retract it back in to use it again?
Unread 04-04-2016, 22:24
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
I don't think they can.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 04-04-2016, 22:45
s_forbes's Avatar
It's a one-shot deal. We have to reload the launching mechanism before each match.
Unread 04-04-2016, 22:48
IamBuild IamBuild is offline
AKA: Adam Damato
FRC #3357 (Comets)
IamBuild is an unknown quantity at this point
I strongly think climb is within reach for just about everyone (To the point where I'm thinking about designing a "Climb in a box" cheesecake).With only 3.3 ounces I made a launch tube, hook, and rope that has a 95% success rate. It's shot with pneumatics and if you include the motor, winching system, and the solenoid, the whole system can weigh under 3 pounds. If you have any questions about this feel free to ask and I have some pictures of it here: https://docs.google.com/presentation...it?usp=sharing
Unread 04-04-2016, 23:17
trumpthero786's Avatar
trumpthero786 trumpthero786 is offline
What Part of the Sandwich Are You?
AKA: Humza
FRC #2729 (Storm Robotics)
Team Role: Electrical
Rookie Year: 2015
trumpthero786 will become famous soon enough
Woah. That's awesome. It's like a piston, but the extender is the hook. I like that 95% success rate (don't know what the sample size is, though) but it seems a little surprising with that hook design. I would expect it to fall off easily. Do you have video of you testing it?
Edit: Just read the line "Hook is made to rebound off the slant behind the hook on the tower to then be pulled back and grab on." This seems more feasible for the hook design.
CLAP CLAP WHOOSH!
2015 - Hatboro Horsham - Quarterfinalist with 272 and 5181 - Entrepreneurship Award
2015 - Seneca - Quarterfinalist with 316 and 5684 - Engineering Inspiration Award
2015 - MAR Championships - 50th Seed - Quarterfinalists with teams 1923 and 11
2016 - Hatboro Horsham - Team Spirit Award
2016 - Seneca - Gracious Professionalism Award
"nice beaver tail"
Unread 04-04-2016, 23:44
AKA: Adam Damato
FRC #3357 (Comets)
Sample size is out of 40. The idea behind it is the round bar near the base causes it to rotate towards the heavy side (The hook) when getting pulled over. It seems to work nearly 100% of the time if you go slowly. But even when pulled quickly it has a tenancy to bounce off of the tower and center itself onto the bar. The margin of error is pretty big especially when it is shot up close to the wall so even if it hits lower down on the tower it has enough power to ricochet off the slope and over the bar.
Unread 06-04-2016, 17:05
Kevin_Crossland Kevin_Crossland is offline
FRC #3324
Kevin_Crossland is an unknown quantity at this point
Funny enough this is actually almost identical to my original idea. I'm curious, have you passed inspection with this system yet? Is this mechanism legal, it would appear to conflict with rule R76, specifically
"Do not, for example, paint, file, machine, or abrasively remove any part
of a pneumatic COMPONENT – this would cause the part to become a
prohibited item. Consider pneumatic COMPONENTS sacred."
please let me know if this would be legal, cause I'd love to use a system like this on our own robot
Unread 06-04-2016, 17:27
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
It looks like it's a literal air cannon - there are no pneumatic cylinders involved. The fitting isn't modified, it's just attached. Inspection would be easy so long as the housing for the canon isn't PVC, PolyCarb, Fiberglass or other material that is prone to splintering during an extreme failure event.
GitHub
Unread 06-04-2016, 18:39
FRC #3324
the question I guess would be if it classifies as pneumatic component, I figure if worse comes to worse it's a pressure relief with a conveniently placed harpoon
