Go to Post Now if MTV had an episode of "Made" where the school's top jock wanted to drive a FIRST's teams robot to victory...now that would be a good one. - Koko Ed [more]
Unread 04-04-2016, 13:39
philso philso is offline
FRC #2587
Re: COMM lost way to many times
Originally Posted by AllenGregoryIV View Post
One of the other things that hasn't been metioned is the use of ferrules with the weildmuller connectors. We used them on nearly all of our competition robot connections and have had zero issues.
Here is the white paper from Weildmuller recommending their use with stranded wires.
We import ours from China using Aliexpress but you can also get them from US electronics vendors, ebay, or Amazon.
Make sure you are using the right crimp tool and gauge ferrules. Also get 8mm long ones.
We got our ferrules from www.ferrulesdirect.com and our crimper from amazon. We found that installing ferrules on our 16AWG wires (i.e. from the compressor) made them too large to work with the Weidmuller connectors.
The cable that came in our KOP had a right-angle plug on it. Once it was plugged in, wrapping a long cable-tie around the radio and the plug worked well to keep it plugged in very securely. We were able to pass the cable-tie under the radio, between it's "feet", so it could not slip off.
