Go to Post ChiefDelphi is talking about women's clothing. What a time to be alive. - Karibou [more]
Unread 02-04-2016, 23:52
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Rookie Year: 2015
Roboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to all
Re: Searching For Swerve / Holonomic Drive Idea
I believe this is a hemispherical omnidirectional gimbaled drive or a HOG drive.
Unread 04-04-2016, 13:02
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
No, according to its name a HOG drive uses a tilting hemisphere that spins in one axis (parallel to the hemisphere's circle), whereas these use a full sphere that can spin in 2 axes.
Swerve (and mecanum) technology has progressed a lot since 2003, so today there are much simpler and better ways of making a true omnidirectional drive compared to this pseudo-omnidirectional drive.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 04-04-2016, 13:28
Joining the 900 Meme Team
FRC #0079
Originally Posted by CalTran View Post
1717, 973, 16, and other swerve teams have done it before. It's possible, but as said, requires an absurd amount of coordination.
I've also done it numerous times with omni wheel based drives[1]. With a gyro it's fairly simple actually. Ether has posted enough of the math at this point that it's not bad at all. If you prefer to derive it yourself it's some basic trig.
[1] https://www.youtube.com/watch?v=TW6fR-bQFgI In this video the driver is simply commanding the direction to go (field centric) and a rotation rate. The robot figures out everything else. No coordination needed, this was, I think, Brando trying it out for the first time.
Unread 04-04-2016, 13:59
I'm still trying to find out what makes people call the ball drive something other than a "true omnidirectional" fully holonomic system.
Unread 04-04-2016, 14:04
Ari423's Avatar
FRC #5987 (Galaxia)
Since only the front wheels can impart a sideways force on the robot, the robot will turn (w/ CoR between the back wheels). If all 4 wheels were balls, it would be a true-omnidirectional drive. As it is now, the robot drives more like a car, where the front of the robot can go sideways, while the back of the robot doesn't.
2013: Programmer
Unread 04-04-2016, 14:11
FRC #0079
3 Wheels, you don't need 4.
Alan - I believe this system would have a difficult time translating and rotating at the same time, but, as I haven't built one or played with one I can't confirm this without putting in a bit more thought. But I think that's what folks are getting at. But I think that's based on my mental model of the wheels being the same as an omni wheel and I'm thinking that's not right.
Unread 04-04-2016, 14:52
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
oh boy have I got something for you.
Remind me to revisit this thread in a month when all the craziness of the current season is over. I've got a fun project from a few years ago to share.
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
Unread 04-04-2016, 15:31
You can compensate for that by "tanksteering" the bot in the opposite direction. But that compensation is based on dynamics (forces) not simple kinematics.
With a true swerve it is straightforward to solve the inverse kinematics to get straight-line motion while simultaneously turning. Just make the direction command field-centric.
Unread 04-04-2016, 15:49
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
I heard of a recently released design called the BB 8 don't know much about it but it could be worth looking into.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 04-04-2016, 16:08
Since only the front wheels can impart a sideways force on the robot,...
Are we talking about the same thing? The front wheels on the TechnoKats 2003 "ball drive" 'bot are omniwheels, and can impart only forward/backward forces. The balls are the only thing that can produce a sideways force.
Unread 04-04-2016, 16:27
Chris Endres Chris Endres is online now
Play hard, Work harder
AKA: Topher
no team (Ctrl-Z)
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
Originally Posted by trumpthero786 View Post
I feel like steel would be very slippery on carpet. Traction would be difficult.
Well, purposeful metal-on-carpet is illegal in FRC (according to R6), if that is what you were referring. I would go for a hard rubber ball if I would design this, probably with a ~ 5" diameter.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 04-04-2016, 16:39
Ari423's Avatar
FRC #5987 (Galaxia)
Oh then I was looking at the robot backwards. Make that the back wheels (the balls). The point is with this configuration, the drivetrain cannot travel in all three dimensions (x, y, r) at the same time. You could do it using three wheels set up with two balls in the front (or back) and at least one omni wheel facing horizontal (perpendicular to the front).
2013: Programmer
Unread 04-04-2016, 17:09
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Academic Student (Forever)
Unread 04-04-2016, 17:31
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Fire game!
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 04-04-2016, 19:28
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Would not mecanums be easier to implement than a swerve drive and a ball drive? As an offseason project I like swerve drives more if you have the resources to do it, or mecanum if not.
