Re: Interesting/Cool Scaling Mechanism Designs
It looks like that homebrew compressor was pushing a whole lot more than 1.1 cfm. If you're doing work with air, it's a pneumatic device. (Noted exception for closed cycle air springs.)
If this is true, then all fans and fan-blown vacuum devices on FRC robots are illegal.
It is unclear to me what constitutes a pneumatic device. Obviously nothing custom can be connected to the "canonical" pneumatic system on the robot, which is heavily regulated. EDIT: Vacuums are legal per R77. Other things maybe not. Quote:
so how does a 3d printed fan fill a cheapo innertube to extend...?
could this be the work of a secondary compressor? (it may very well be the same work of the one original with a solenoid allowing for a tank to empty into it... or something... :/ also, i dont know that its the most consistent way to hook onto the bar, seeing as it wobbles here and there when they do it... (again, please let me know if i have the wrong thought train here...) (like, please... pretty please) Last edited by bennettj800 : 04-04-2016 at 18:43. |
I love the confidence with which you make your clearly wrong statement.
How much SWAG is too much SWAG? Last edited by Navid Shafa : 04-04-2016 at 19:12. |
If you don't believe me please point to the rule(s) that prove what you are saying. |
#7
Rule R79:
"Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications must not exceed nominal 1.10 cfm flow rate @ 12VDC." this has already been pointed out... also, a custom fan blowing a tube up (like a balloon) would be, in any circumstance, a compressor, thereby violating this rule. ergo, the custom fan has got to go if it is actuating something like it is. |
#8
Fans are legal per R29: Quote:
#9
FRC doesn't define a compressor but they do say that there shall be only one source of compressed air, and that it must be rated 1.10cfm or less. I don't remember anything about a positive displacement device in the rules... Last edited by GeeTwo : 05-04-2016 at 13:32. |
#10
A fan does not provide compressed air, it provides flow. That is why it is very difficult to even find a rating for delta P for most muffin fans as supplied in the KOP in the past. But I was able to find a rating for for a special "high static pressure" muffin fan for restrictive computer cases. This "high static pressure" fan was able to create a static delta P of .002 PSI when dead-headed. Fans are listed in the rules under the electrical rules, not the pneumatic rules, for the excellent reason that they are not pneumatic devices. The Q&A cited earlier was a question about using air from a solenoid valve attached to the pneumatic system, not a fan. If you are not a member of the GDC, do not cite your opinion as fact (note that I have taken my own advice). |
#11
Until and unless the GDC clarifies otherwise, I'll continue to assume that the manuals are written in American English.
#12
Are my bumpers compressors? When my robot is in motion, there is a rise in static pressure across the surface. What about closed cell foam (like pool noodles are made of)? when force is applied to the foam, the pressure inside the cells of the foam is increased. Every time two robots collide or push against each other they are creating air pressure inside the closed cell foam far in excess of anything that could be produced by a muffin fan. The pneumatic system rules are very clear. Fans are not mentioned, in English or any other language. |
#13
The Manual allows fans, both electronics muffin fans and fans powered by FRC motors. A cloth bag placed over a fan is not containing compressed air - it's just containing air. The bag restricts flow of the air somewhat but it is not airtight - the bag does not stay even close to inflated the second the air is cut. These rules have been the same for years, and in previous years the GDC has explicitly allowed mechanisms just like these. There's substantial historical precedent for these mechanisms (see blockers in 2013, similar hanging mechanisms in 2010, etc). You can't state your opinion as certain fact and then refuse to listen to anyone else's view unless the GDC says so. You're applying different levels of scrutiny to yourself versus others. |
#14
What about those Aussies? And we can't forget the Hawaiians! ------------------------------------------------------------------------ Seriously Gus, your logic just isn't there. From my understanding... If my dump valve happens to dump air into a Versatube somewhere on my robot because its mounted near that, I guess that's part of the pnuematics system now? Introducing the new VEX Versatube with new PNEUMATIC Features! What about the 2013 blocker I remember 116 having at IRI? Last edited by bkahl : 05-04-2016 at 16:44. |
#15
