#16
Re: Colson Performa Safety
The following video is an attempted destruction test of said banding method, the wheel in the video plateaus at 7,750 rpm and the surface of the wheel is seeing nearly 3,000 G's of outward force. https://www.youtube.com/watch?v=vOYEp6tjQDg |
#17
We are using two Colson Performa 4x2 wheels with press fit hex hubs on our shooter. They are driven by mini-cims and Versa Pro pulleys/belts and mounted with thunderhex bearings and 1/2in hex shaft. Max speed is 6,000 RPM and we haven't had any issues whatsoever.
#18
The only thing is you need to press fit hubs into them - Vex sells live and dead axle hubs (though check the OD on them before you press them in, they're sometimes too small / big). It's also not hard to make your own aluminum or delrin hubs if you have a lathe. |
#19
Pfft only 12 000? We have a PG71 running 1:1 via vex sprockets. 70rpm baby!!!! Had to remove since safety was worried the wheels would fly apart pulling the maximum fasts/hour
#20
Dual everything - 775pro --> 4:1 VersaPlanetary --> 1:1 VEX PRO gears transfer --> VEX PRO hex shaft --> 5"x2" Colson wheel/VEX PRO live hub --> 2.5" compression.
NOT a single problem. But, I probably just jinxed us... --Michael Blake Last edited by Michael Blake : 04-04-2016 at 20:51. |
