Go to Post Don't get mad, learn, and get even. - Eric O [more]
Unread 05-04-2016, 09:40
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Programming Buttons
Are you using the command based framework? If so, you can easily make commands for all of these tasks. Just use the setTimeout method in initialize() to set it to run for the amount of time you want, and return isTimedOut() in isFinished.
Then, get JoystickButton objects out of your Joysticks and attach commands to them.
