Go to Post Don't be in a rush to build a robot until you know what robot it is you need to build. - Chris Fultz [more]
Unread 05-04-2016, 09:45
michchinn michchinn is offline
FRC #5404 (Gearaffes)
Team Role: CAD
michchinn is an unknown quantity at this point
In Need of Gears and 775pros
Before MAR Champs in a week and a half, Team 5404 needs 3 20t aluminum gears with 1/2" hex bores for the 3rd stage of our VexPro ballshifter drive gearboxes.
We have already replaced one on our competition robot after it stripped, and the second on the competition robot as well as the two on our practice robot are all nearly stripped as well.
We would also like 2 775pro motors before the event. After we smoked our shooter motors at the Westtown district event we used our remaining spares.
Does anyone have any spares of these parts?
We can cover the costs for shipping from wherever you are, or pick them up if you are near us (we are in Lansdale, PA).
Thank you.
The Heart Attackers/WMS Blue (FLL) 2010 - 2013
341 Miss Daisy (FRC) 2013 - 2015
5404 The Gearaffes (FRC) 2015 -
Unread 05-04-2016, 09:50
Aren_Hill's Avatar
Build Nifty Things
Re: In Need of Gears and 775pros
Thank you.
Since we are out of the 20T aluminum gears for this season, these gears are compatible but will require you to get them hex broached.
Martin Gears on Amazon
Sorry I cannot help on the 775pros.
-Aren
A guy who likes robots.
Unread 05-04-2016, 10:19
ezygmont708's Avatar
ezygmont708 ezygmont708 is offline
FAIL = First Attempt In Learning
AKA: Zygmont
FRC #0708 (Hatters Robotics)
ezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant future
If you PM me, team 708 may be able to help with the gears... or if you have my email that would be better :-)
E. Zygmont
Team Lead - Team 708 Hatters Robotics
Hatboro- Horsham Senior High School - Horsham, PA
Unread 05-04-2016, 10:24
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
If you're going to broach 20T 20DP gears that are round into hex and don't mind a little key cutout these gears from AndyMark are a bit cheaper than the ones on Amazon.
Not too hard if you already have a broach and press. Also the steel gears may not wear as fast.
-matto-
Unread 05-04-2016, 10:38
Team Role: CAD
Will using a steel 20t gear in the 3rd stage accelerate wear on the aluminum 64t gear that it meshes with in the third stage?
Thank you all for your help and suggestions.
Unread 05-04-2016, 10:53
AKA: -matto-
FRC #1410 (Kraken)
Perhaps. There is a lot of discussion about 3rd stage gearing wear for a Ball Shifters on this thread. I would contact some of the folks on there that have put these gearboxes through very, very tough trials.
-matto-
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
The answer is probably yes depending on the hardness of the smaller steel gear and coatings on the aluminum gear.
Good news though. for the run times of a typical FRC robot, it wont matter much. The larger gear will almost always wear more slowly than the smaller gear because each tooth on the larger gear will see fewer cycles. With matches only a few minutes long and seeing a maximum of 21 at an event (except for replays) the aluminum gear should not be seeing much wear in the 40 minutes or so it is going to be running for.
However, in the future I would advise you to not use aluminum gears unless you are right up against the weight limit or are using very large gears (team 25, I am looking at you with those massive gears on your wheels...) Steel has better wear and fatigue properties in general. If you are really concerned about durability of the gears you can always have them case hardened. I did this to an old toughbox that I use for a 6000 watt motor (~15 CIM equivalent) to power a silly electric racing car and I have run under load for about 15hrs with almost no signs of wear.
Unread 05-04-2016, 10:57
Chris is me's Avatar
AKA: Pinecone
Yes, but if you properly lubricate your gears they will not wear significantly within the runtime of an FRC robot, and this will not compromise performance. Aluminum gears like to wear a little until they run nicely and then that tapers off for a bit.
However, I would advise you to not use aluminum gears unless you are right up against the weight limit or are using very large gears (team 25, I am looking at you with those massive gears on your wheels...) Steel has better wear and fatigue properties in general.
There is nothing wrong with using aluminum gears in FRC - the weight savings is dramatic and for most applications the strength is just fine. The aluminum gears Vex produces are of higher quality than steel gears from AndyMark as well - better tooth profile, more consistent manufacturing, etc. Wear and fatigue properties are not really a concern with 100-200 hour run times.
Unread 05-04-2016, 11:01
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We have a 775pro but are out on long Island so a bit of a hike.
Unread 05-04-2016, 11:04
doctorflems doctorflems is offline
FRC #4506 (PioNerds)
Rookie Year: 2015
doctorflems is an unknown quantity at this point
On those 775Pros-
To keep brushes from smoking out like that, it is absolutely essential to have airflow past them. Lots of airflow, since you have to keep the brushes cool.
Also, avoid applying full power are low speeds.
Unread 05-04-2016, 12:18
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Is it possible for you to have BaneBot 775's as backup? Are you using 775pros on anything other than your shooter? If so, can those be switched to BaneBots giving you a backup 775pro?
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 05-04-2016, 12:19
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
-matto-
We went to 3 regionals this year and wore through 5 20T VexPro gears with our 3rd stage of Ballshifters. We ended up switching to the Andymark steel gears (broached hex). At the end of our Idaho regional, our 64T VexPro gears were trashed, luckily we had replacements for those.
Some of our issues were due to the lack of securing the 3rd stage to the BallShifter. We were having a lot of binding when we tightened the 3rd stage too much, so we tried to find a happy medium between too loose and too tight, we think this caused some issues with gear tooth engagement when it experience shock loading.
This year was rough on drive trains.
Unread 18-04-2016, 01:00
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
For those of you that broached gears how did you align things?
I tried a rotary broach in a Bridgeport but found it difficult to get a good center. The existing keyway in the gear would end badly on a coaxial indicator. I tried a few times with a 0.2 edge finder and the DRO but still managed to be broached straight but slightly off center.
It is either I am off center or my back plate protecting my chuck face is not rigid enough. It is strange because I drill out the hole to 33/64" and chamfer before I go in. Center does not move. I have not tried this much lately....maybe just have not gotten the knack of it.
Unread 18-04-2016, 01:06
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
We use a standard push broach, and it works fine for keyed gears. Fine enough for FRC, anyway.
Unread 18-04-2016, 01:20
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
If you have a rotary broach, I would use the lathe instead of the mill.
R.C.
MadTown Robotics Team 1323
