Go to Post Play FRC like Bruce Lee, not an MMA fighter. - Jessica Boucher [more]
Unread 05-04-2016, 00:35
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: pic: Winch-atize me, Cap'n!!
Originally Posted by Fusion_Clint View Post
Nice, I love the design.
I highly suggest steel gears for the final stage
Unfortunately Andymark does not sell 18 tooth steel gears with a 1/2 inch hex bore.
While the final stage gears might not be able to take the stall torque generated by the 775's, the ratchet means that the motors should never need to be be stalled.
Facebook
Unread 05-04-2016, 09:07
Chris is me's Avatar
AKA: Pinecone
It's not even just stall torque - it's torque under load, particularly with the long cantilever on the shaft. Pulling your robot up with one of these should work for awhile, but before you know it, you could snap teeth on that pinion gear, fall from the tower, and lose your regional. Happened to me in 2013. Still bitter.
If you could somehow double the face width of that gear (second pinion / output gear) that would help I think. Maybe you'll be okay with this, I dunno.
Unread 05-04-2016, 09:40
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Originally Posted by trumpthero786 View Post
Looks very well built! I love custom gearboxes like this. I'd also love to see the rachet and pawl. It sounds better than using a socket wrench Thanks for sharing this!
What's wrong with ratcheting wrenches?
It isn't shiny enough.
Unread 05-04-2016, 10:46
BumblingBuilder's Avatar
BumblingBuilder BumblingBuilder is offline
Red is fast
AKA: Matthew
FRC #2169 (KING TeC)
BumblingBuilder will become famous soon enough
How much does the entire apparatus weigh? Our team has been experimenting with mechanisms under intense weight constraints, and I'm interested in how much such a wickedly powerful custom gearbox setup such as this weighs.
2014: FRC 2169 scouting/spirit, FTC 7897 Mechanical
2015: FRC 2169 Mechanical/CAD
2016: FRC 2169 Mechanical/CAD
2017: FRC 2169 Head of Mechanical
Unread 05-04-2016, 12:14
Chris Hapstack's Avatar
Chris Hapstack Chris Hapstack is offline
Design Mentor
FRC #0342 (Burning Magnetos)
Chris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to behold
I highly suggest steel gears for the final stage, we were using the vexpro gears and broke several teeth during the Bayou Regional which is the reason we were not able to hang during the quarter finals.
Thanks for bringing up the gear tooth failure issue! If we end up breaking teeth, the plan is to buy some steel replacements from Boston Gear and hex-broach them ourselves. Also, I’m sure the winch could tear itself apart in many different places if it actually tried to lift 1000 pounds.
The entire winch system here comes to 4.7 pounds (was hoping to get closer to 4, but oh well). That doesn’t include speed controllers, though.
2017 -------- Team 342 mentor (Charleston, SC)
2015-2016 - Team 85 mentor (Zeeland, MI)
2007-2010 - Team 281 student (Greenville, SC)
Unread 05-04-2016, 14:22
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
They do sell this 19 tooth one, which I bet would also work.
http://www.andymark.com/Gear-p/am-0176.htm
We wound up using one of these paired with a this mecastercarr gear that we machined the bore ourselves. http://www.mcmaster.com/#6325k73/=11up3mm
Just trying to help.
It wasn't our first choice, but is nice not breaking teeth every other match.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 05-04-2016, 15:12
Design Mentor
Yeah absolutely, thanks a bunch!
