Go to Post Dean looks rather debonaire in a tux. Like some sort of engineer super hero. The tuxedo is like his Clark Kent costume under which lies his amazing denim suit, to be whipped out at a moments notice in the face of uninspired youth and problems unconquered. - phrontist [more]
Unread 31-03-2003, 23:06
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Doing what we do best
Unread 31-03-2003, 23:08
tonyargote's Avatar
tonyargote tonyargote is offline
#0059 (RamTech 59)
tonyargote is an unknown quantity at this point
Send a message via AIM to tonyargote Send a message via Yahoo to tonyargote
WOW
How well did this arm design work? I had some doubts as to the Amount of leverage a robot would have over yours should it be on the other end of the arm. How well did it perform?
TArgote
Driver, Programmer, Webmaster
www.RamTech59.com
UCF: Ranked 13th (2nd Highest QP's in the Nation! (349))
Championship: Ranked 12 out of 73 teams in Archimedes Division, Quater finalist allied with 1108 (GO 1108!) & 868 ( GO 868!)
Unread 03-04-2003, 01:53
Alaina's Avatar
Alaina Alaina is offline
J = Pf - Po
FRC #0814 (Megaforce Squadron)
Alaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to behold
Send a message via AIM to Alaina
I really like the angle that photo was taken at.
Is that arm just for sweeping?
"It's cool to be a geek!" -- Dave Lavery
"It's all about the math." -- Mark Leon
Unread 03-04-2003, 09:56
Kojib Kojib is offline
#0016 (Baxter Bomb Squad)
Kojib is an unknown quantity at this point
Send a message via ICQ to Kojib Send a message via AIM to Kojib Send a message via Yahoo to Kojib
Just want to point out a flaw in robots designed like this. That long arm acts like a giant moment arm. Couple that with a robot that is usually top-heavy (most robots I've seen with a design like this are). These two things spell trouble if you encounter a robot that gets up to the ramp real quick and is high enough to "interact" with your arm. Those of you interested, check out the Midwest Regional's first quarter final match between teams 16/65 vs. 71/167. The file name is il_qf4m1 on www.soap108.com
Unread 03-04-2003, 10:06
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
But look at their arm. It's teloscopic. Unlike other teams, this arm is light and won't tip over the bot.
Unread 03-04-2003, 12:51
Everyone elses arms are telescopic, they have to be.
Unread 03-04-2003, 12:54
Matt Brinza Matt Brinza is offline
Matt Brinza is an unknown quantity at this point
On the contrary...
Team 71's arm was also telescopic. Materials used in the construction of the arm are negligible. What really counts is where the CG is, and whether or not the arm gives in case of a collision (as shown in the movie Kojib was referring to: http://www.soap108.com/2003/movies/il/il_qf4m1.asf)
Unread 03-04-2003, 14:23
David Hoff's Avatar
David Hoff David Hoff is offline
FRC #4050 (Biohazard)
David Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to all
Unlike most arms Cyber Blue's flailer is not telescoping and it is quite heavy. In one match at the VCU Regional our flail did hit Metal in Motion during autonomous mode, and if I am correct our robot did not even move, let alone fall over.
Cyber Blue Team 234: Indianapolis, IN 2002-2006
Purdue FIRST Programs: West Lafayette, IN 2006 - 2010
Cyber Titans Team 3793: Frederick, MD 2012
Biohazard Team 4050: Chambersburg, PA 2014
Unread 03-04-2003, 15:05
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
I think it's really a matter of how rigid the swinging joint is. When 71 got hit, the whole arm moved with 16, and caused Beatty to fall over. If the joint were to pivot when hit, however, such an arm could be turned with knocking the robot down.
Jeff Waegelin
Unread 03-04-2003, 17:24
Brett W Brett W is offline
#0843 (WYVERNS)
Brett W is on a distinguished road
Yes our robot was top heavy and we did fall three times but only in practice rounds. On our arm we used the battery to act as a counter balance so that our robot was more balanced than most robots with arms. we found out that if we drove up the ramp backward our battery also helped us from tipping over and by accident we turned out to be a really good king of the hill robot.
we have a simple drive train. 2 drills in low gear with a 3:1 gear ratio in sprockets. our tires were what made us so good on top of the ramp. we have 4, 3" wide tires with some really soft rubber that is really grippy. we had so much traction we had the dancing robot problem even on top of the ramp. we were on top of the ramp in every heat except one where we over powered another robot and went a little to far a tiny piece of rubber was hanging from our tire and that was touching the ramp. it took 5 minutes for the judges to make the call. if we had been 1 inch back we would have been on top of the ramp and got 75 QP's instead of 3 QP's which we got.
The Picture is one of the match where there was a robot fast enough to beat our arm to the stack. our arm actually over powered the robot and prevented it from crashing through in auton mode. although once auton mode ended it got another run at it and got through while we were taking another swing at the wall.
I feel that this strategy is one of the best. we also used our arm to reach over other robots to knock over human player stacks even when they were being guarded.
Even though we had a good working robot and strategy we still weren't picked for the playoffs and that 3 point score in our last heat where we weren't quite on top of the ramp dropped our average and blew our chances at getting in to the top 8. It was still a good year and i wish that we could go to another regional or the nationals but our school board has put a ban on out of country field trips. Looking forward to next year and thanks for all the positive comments about our arm.
Team Captain
843 WOW
Brett
Unread 03-04-2003, 18:23
Simeon Simeon is offline
#0820 (DeltaTech)
Simeon is an unknown quantity at this point
it was quite a nice looking robot actually...
hi.. it's one of the ppl in blue tshirts across from u at canadian regionals... team 820.. came 6th.. yeah..
nehoo.. it was a really nice looking robot u had there...
i just remember that one time the arm didn't work as well tho.. because someone had nudged your robot over during automous before your arm had the time to swing all the way over...
nehoo.. it was fun at the comp
u guys did a good job tho
too bad the 3 point round dropped you so much...
i liked ur uniforms too, eh?
Unread 04-04-2003, 23:37
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Says who?
http://www.chiefdelphi.com/forums/sh...threadid=18975
Go against the norm.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 06-04-2003, 15:04
Jonathan M.'s Avatar
Jonathan M. Jonathan M. is offline
One Nation Under-Educated
AKA: Spider-Punk
None #0845 (Cutting Edge)
Jonathan M. has a spectacular aura aboutJonathan M. has a spectacular aura about
Send a message via AIM to Jonathan M. Send a message via MSN to Jonathan M.
I Think it was team 176 that had an arm like this at UCF this year. It did get flipped over one time but it used its arm to flip it self back over and continue with the match. I thought it was a great design.
- Jon
2005 Florida Regional Finalists with 1251 (Tech-Tigers) and 1270 (Red Dragons)
2005 Florida Regional General Motors Industrial Design Award winners
2005 Pallmeto Judges Award winners
My art site.
My myspace profile.
Unread 06-04-2003, 21:16
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
the only over the wall arm bot at ucf was team 147 deep thunder, unless i'm mistaken
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 06-04-2003, 21:21
AKA: Spider-Punk
Thats correct I think. I was talking based on (bad) memory. But after checking up, I find I was wrong. But what ever.
- Jon
My art site.
My myspace profile.
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
need window motor pic!! Rickertsen2 Motors 3 04-02-2003 21:50
Who am I pic... Pamela CD Forum Support 6 23-07-2001 23:49
