Go to Post Ive been chewing on my yellow food wristband every night since the team party on friday at UTC. Every day it tastes better and better...almost as good as the food. Anyone else think so? - Sscamatt [more]
Unread 05-04-2016, 16:33
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Arduino + Jaguar Speed Controller + CIM Motor
It's coming back to me, what you have looks fine, I'd be tempted to stick with it, and add the delay to the loop... that maybe the issue. From the map command it should be 0 to 179, not sure what happens when you tell it 180... maybe add the delay, set it up 0 to 179, then calibrate the jag, and then see if it behaves.
The sooner we get behind schedule, the more time we have to catch up.
Unread 05-04-2016, 20:35
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
I wrote a library for this
https://sourceforge.net/projects/ard...?source=navbar
its makes running motor controllers really easy.
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
Unread 14-04-2016, 10:33
NickLD3753's Avatar
NickLD3753 NickLD3753 is offline
FRC #3753 (BulahBots)
Rookie Year: 2015
NickLD3753 is an unknown quantity at this point
Hi, I think what your issue is might be with the default pulse-width of the signal coming from the Servo library.
Some manufactures decide to vary their input range from the standard timings. Also, most RC servos (what the Library was made for) have a different range from what I have seen FRC Controllers use most of the time.
I did a quick look for the Jaguar Datasheet and found this:
http://content.vexrobotics.com/docs/...t_20130220.pdf
This is what the Datasheet says about the input range:
Minimum pulse width 0.67 ms
Neutral pulse width 1.5 ms
Maximum pulse width 2.33 ms
All We need to do now is convert the ms to us:
Minimum pulse width 670 us
Neutral pulse width 1500 us
Maximum pulse width 2330 us
Now the great thing about the servo library is the ability to skip the scaling of the normal RC servo range and just input the raw us timing values.
myservo.writeMicroseconds(UsTiming);
After that It should be pretty easy to map the values accordingly.
I hope that solves your issue!
Unread 14-04-2016, 11:16
Please don't forget that the CIM motor has a brush bias that is optimized for one direction over the other. While it is slight, there are production variances that may make individual motors respond differently. Other motors are known to have greater bias differences.
Unread 14-04-2016, 16:00
Michael Hill's Avatar
Could you tune this by loosening the bolts, and rotating the black section that houses the permanent magnets (Not saying this would/should be legal on an FRC robot, just technically possible). There are tick marks on each of the sections so you could potentially reliably clock the magnets in relation to the brushes.
