Go to Post [Don't] celebrate mediocrity and want the losers to have an equal chance? Please. Work your butt off for six weeks, keep doing it until you have taught yourself how to be excellent, and go and instead of waiting for a handout. - DonRotolo [more]
Unread 05-04-2016, 15:57
Wyspar Wyspar is offline
FRC #5132 (RoboClovers)
Rookie Year: 2015
Wyspar is an unknown quantity at this point
What does SendableChooser.GetSelected() return as?
http://first.wpi.edu/FRC/roborio/rel...leChooser.html
The library says it returns as a void pointer, but what does that information return like? Does it return the name of the option that is put in with this,
autoChooser.AddObject("Lowbar Auto", new Auto);
"Lowbar Auto" is the name of the option, and can I use it in an if statement like,
if (autoChooser.GetSelected() == "Lowbar Auto") {
//Stuff for lowbar auto
Unread 05-04-2016, 16:36
heuristics heuristics is offline
FRC #3634
heuristics is on a distinguished road
Re: What does SendableChooser.GetSelected() return as?
I haven't used C++ for robot programming but being familiar with C and C++ APIs, it looks like it will return the object you passed in as the second parameter to AddObject().
This code:
would not work because it would compare the void* (address) to the address of the "Lowbar Auto" string literal (char*, wchar_t*, etc. depending on compiler). Instead, you should cast the return value of GetSelected() back to the pointer type which you passed in. Then you can dereference it, or do whatever else you need in order to decide what auto mode to run.
Also,
is likely to cause a memory leak since the SendableChooser won't be able to delete the Auto as it will see it as a void*. You will probably need to manage that object yourself.
Unread 05-04-2016, 16:43
Rookie Year: 2015
I knew already it didn't work, so that's why I was asking. And I found the solution anyways
autoSelected = *((std::string*)chooser->GetSelected());
if(autoSelected == autoNameCustom){
//Custom Auto goes here
} else {
//Default Auto goes here
Unread 05-04-2016, 16:46
FRC #3634
Out of curiosity, did you also change your second parameter to AddObject to a std::string?
Unread 06-04-2016, 11:36
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
It returns a void*, which you cast to a Whatever* that you passed into AddObject (in your case, Command*)
// Then in autonomous init
((Command*) autoChooser.GetSelected())->Start();
(A templated SendableChooser might solve this confusion)
It's not a memory leak since you'd never normally delete your auto commands anyway.
Unread 06-04-2016, 12:47
Rookie Year: 2015
Yes I did, but I just didn't show it.
