Go to Post For Pete's sake, don't concentrate on the entry itself... concentrate on what your team is doing to make an impact in your community. - Andy Baker [more]
Unread 05-04-2016, 16:58
Matthew Zwinger's Avatar
Matthew Zwinger Matthew Zwinger is offline
Head Of App Development
FRC #2169 (KING TeC)
Matthew Zwinger is an unknown quantity at this point
Serial Port Communication
In java we are using serial port.port.kusb on a 9600 baudrate with a nvidia tegra serial port. When we try testing the tegra serial with an arduino it returns garbage askII characters. eg.(Python)ser.write('hello'.encode('utf-8')). The communication port returns this ░:: and then goes to a newline.
Any help would be very welcome.
Unread 05-04-2016, 17:56
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Serial Port Communication
Couple of thoughts:
1. Are you able to decode UTF-8 correctly and why not use ASCII?
2. Stop bits? Data bits? Flow control?
3. How are you deriving your clock for the serial on the Arduino?
4. Which equipment is setup for DTE and which DCE?
Know nothing about serial hides the Trellis modems under the couch.
Unread 05-04-2016, 18:25
Tyguy56 Tyguy56 is offline
FTC #3385
Tyguy56 is on a distinguished road
Originally Posted by techhelpbb View Post
Couple of thoughts:
1. If we encode it or not it still returns garbage ascii characters
2. stopbits 1
3. The hardware it setup with only Tx, Rx, and Gnd. Does the Rio have the other lines? Do you know if Arduino has the other lines as well?
our setup is the serial port on the tegra into the arduino using the tx rx and gnd from there a usb cable into a computer with putty to monitor the com port
simple serial code (python)
    import serial
    ser = serial.Serial(
        port='/dev/ttyS0',
        baudrate = 115200,
        parity=serial.PARITY_NONE
        stopbits=serial.STOPBITS_ONE,
        bytesize=serial.EIGHTBITS
    if(ser.isOpen()):
        ser.close()
    ser.open()
Unread 05-04-2016, 18:44
techhelpbb's Avatar
Originally Posted by Tyguy56 View Post
    import serial
        port='/dev/ttyS0',
        baudrate = 115200,
    if(ser.isOpen()):
        ser.close()
    ser.open()
Uhm your first post said 9600 baud.
Are you using 115200 to the Arduino but only 9600 between the Arduino and the Tegra?
Unread 05-04-2016, 18:50
FTC #3385
sorry forgot to update the post, no we are using the same baudrate
Unread 05-04-2016, 19:04
In java we are using serial port.port.kusb on a 9600 baudrate...
Your code says you're transmitting at 115200. That would definitely give you the kind of short garbled results that you describe.
Why are you encoding as UTF-8? It does end up being the same actual byte stream for straight ASCII* characters, but anything outside the ASCII range will be sent as multiple bytes that your terminal might not understand.
* American Standard Code for Information Interchange, pronounced "ask-ee"
Unread 05-04-2016, 19:28
FTC #3385
sorry im new to serial coms would it be better to not encode at all?
if I run at 9600 baudrate and no encoding with the same setup (tegra serial port to arduino and arduino to computer then open com port on putty) it only returns ░:: h̶o̶w̶e̶v̶e̶r̶ ̶a̶f̶t̶e̶r̶ ̶t̶e̶s̶t̶i̶n̶g̶ ̶a̶d̶d̶i̶t̶i̶o̶n̶a̶l̶l̶y̶ ̶w̶h̶e̶n̶ ̶t̶h̶e̶ ̶s̶a̶m̶e̶ ̶s̶e̶t̶u̶p̶ ̶i̶s̶ ̶r̶a̶n̶ ̶o̶n̶ ̶t̶h̶e̶ ̶r̶o̶b̶o̶r̶i̶o̶ ̶i̶t̶ ̶w̶i̶l̶l̶ ̶r̶e̶t̶u̶r̶n̶ ̶w̶h̶a̶t̶ ̶I̶ ̶a̶s̶s̶u̶m̶e̶ ̶i̶s̶ ̶r̶a̶n̶d̶o̶m̶ ̶b̶y̶t̶e̶s̶ ̶e̶g̶.̶ ̶[̶B̶@̶8̶c̶f̶4̶c̶6̶[̶B̶@̶e̶d̶c̶d̶2̶1̶[̶B̶@̶c̶4̶5̶d̶c̶a̶ ̶e̶t̶c̶ ̶e̶t̶c̶ ̶w̶i̶t̶h̶ ̶n̶o̶ ̶p̶a̶t̶t̶e̶r̶n̶ ̶
̶U̶P̶D̶A̶T̶E̶ ̶I̶ ̶a̶l̶s̶o̶ ̶n̶o̶w̶ ̶g̶e̶t̶ ̶e̶r̶r̶o̶r̶s̶ ̶i̶n̶ ̶m̶y̶ ̶r̶i̶o̶l̶o̶g̶ ̶w̶h̶i̶c̶h̶ ̶s̶a̶y̶ ̶W̶A̶R̶N̶I̶N̶G̶:̶ ̶R̶o̶b̶o̶t̶s̶ ̶d̶o̶n̶'̶t̶ ̶q̶u̶i̶t̶
Unread 05-04-2016, 19:33
FTC #3385
Okay fixed a couple errors, hooked it up to the roborio and initiated a serial connection there at 9600 baudrate now it prints out to the riolog when I do a system.out.println(serial.readString()) however I am doing no encoding so just ser.write('hello') I am now getting in my riolog ?::
Unread 05-04-2016, 19:52
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
This thread might help you
Unread 05-04-2016, 20:47
FTC #3385
Thank you everyone, after going to http://www.chiefdelphi.com/forums/sh...d.php?t=132680 (special thanks to orangelight for the link) we learned that another team solved this by using the usb port instead of the serial port and then used a usb prolific rs-232 converter directly into the rio. Thank you all for your help!
Unread 06-04-2016, 06:54
techhelpbb's Avatar
So you worked around it.
It seems like a timing issue.
