Go to Post Yes, you are correct. Even when all other databuses are totally out of bandwith, the PainInTheCalf Bus gets top priority. Good thinking ;-) - Joe Johnson [more]
Unread 05-04-2016, 19:28
Tyguy56 Tyguy56 is offline
FTC #3385
Tyguy56 is on a distinguished road
Re: Serial Port Communication
Originally Posted by Alan Anderson View Post
Your code says you're transmitting at 115200. That would definitely give you the kind of short garbled results that you describe.
Why are you encoding as UTF-8? It does end up being the same actual byte stream for straight ASCII* characters, but anything outside the ASCII range will be sent as multiple bytes that your terminal might not understand.
* American Standard Code for Information Interchange, pronounced "ask-ee"
sorry im new to serial coms would it be better to not encode at all?
if I run at 9600 baudrate and no encoding with the same setup (tegra serial port to arduino and arduino to computer then open com port on putty) it only returns ░:: h̶o̶w̶e̶v̶e̶r̶ ̶a̶f̶t̶e̶r̶ ̶t̶e̶s̶t̶i̶n̶g̶ ̶a̶d̶d̶i̶t̶i̶o̶n̶a̶l̶l̶y̶ ̶w̶h̶e̶n̶ ̶t̶h̶e̶ ̶s̶a̶m̶e̶ ̶s̶e̶t̶u̶p̶ ̶i̶s̶ ̶r̶a̶n̶ ̶o̶n̶ ̶t̶h̶e̶ ̶r̶o̶b̶o̶r̶i̶o̶ ̶i̶t̶ ̶w̶i̶l̶l̶ ̶r̶e̶t̶u̶r̶n̶ ̶w̶h̶a̶t̶ ̶I̶ ̶a̶s̶s̶u̶m̶e̶ ̶i̶s̶ ̶r̶a̶n̶d̶o̶m̶ ̶b̶y̶t̶e̶s̶ ̶e̶g̶.̶ ̶[̶B̶@̶8̶c̶f̶4̶c̶6̶[̶B̶@̶e̶d̶c̶d̶2̶1̶[̶B̶@̶c̶4̶5̶d̶c̶a̶ ̶e̶t̶c̶ ̶e̶t̶c̶ ̶w̶i̶t̶h̶ ̶n̶o̶ ̶p̶a̶t̶t̶e̶r̶n̶ ̶
̶U̶P̶D̶A̶T̶E̶ ̶I̶ ̶a̶l̶s̶o̶ ̶n̶o̶w̶ ̶g̶e̶t̶ ̶e̶r̶r̶o̶r̶s̶ ̶i̶n̶ ̶m̶y̶ ̶r̶i̶o̶l̶o̶g̶ ̶w̶h̶i̶c̶h̶ ̶s̶a̶y̶ ̶W̶A̶R̶N̶I̶N̶G̶:̶ ̶R̶o̶b̶o̶t̶s̶ ̶d̶o̶n̶'̶t̶ ̶q̶u̶i̶t̶
Unread 05-04-2016, 19:33
FTC #3385
Okay fixed a couple errors, hooked it up to the roborio and initiated a serial connection there at 9600 baudrate now it prints out to the riolog when I do a system.out.println(serial.readString()) however I am doing no encoding so just ser.write('hello') I am now getting in my riolog ?::
Unread 05-04-2016, 19:52
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
This thread might help you
Unread 05-04-2016, 20:47
FTC #3385
Thank you everyone, after going to http://www.chiefdelphi.com/forums/sh...d.php?t=132680 (special thanks to orangelight for the link) we learned that another team solved this by using the usb port instead of the serial port and then used a usb prolific rs-232 converter directly into the rio. Thank you all for your help!
Unread 06-04-2016, 06:54
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
So you worked around it.
It seems like a timing issue.
