Re: [FF]: 2016 Season Long Fantasy FIRST
Last year, the "Octofinals" flowed through as regular qualification matches, which may severely complicate things. Let's hope that Octofinals flow through as their own set of playoff matches. - Sunny G. |
Visuals! (I know i'm slow)
The distinct clumps are definitely forming within the ranks, the battle for world champs draft positioning is on! ![]() ![]() New visual for you for highest event score: Leauge high is RFA at Australia with 246. ![]() And here is how districts only are shaking out. Interesting how much larger the %gap is btwn this and overall scores. ![]() Also can we get a final ruling on that 2771 swap Eric? |
If they've played twice in districts, that's a no. The call was after one play, not two.
So now we have ourselves a bit of a schedule for the remaining DCMP drafts. Subject to change, of course...
Nobody drafts tomorrow night--giving a little time for the lists to be put together. MI and New England will draft on Monday night (they're done first). I'll take MI, but someone needs to cover New England. MAR drafts on Tuesday. Wednesday sees Peachtree close out the regular-season drafts. Championship drafting: We'll start that on 4/21, running two fields/night. I can cover most of those, but will need some help. If some folks step up, that could be opened up on 4/20 instead. |
I have updated the live scoring sheet and will do so again after matches finish today. Regular season scoring won't be truly final until Sunny gets to it, just a heads up. |
#7
There were some problems with the API with the octofinals; Frank Merrick was dealing with it at PCH with Danny, but it should be fixed now, in theory.
#8
Not a problem, fellas. I don't expect we'll need the finishing order until at least Wednesday (when we'll need it to set up the Championship drafts).
#9
I've implemented the Octofinalist logic for MSC.
It should be good/correct, but I threw it together quickly at the airport. As such, I'd appreciate if someone could double check the work and make sure the numbers make sense. Thanks, - Sunny G. |
#10
*Elims portion of my MSC manual scoring attached* Last edited by Navid Shafa : 17-04-2016 at 14:00. |
#11
Should be fixed, - Sunny G. |
#12
Before scores are final, Brennan noted today that there are two No-Shows on rosters for the PCH DCMP that need to be swapped for randoms. No random list is posted, do you have it Eric?
Swamp Life: 3635 The ULCAN: 5594 |
#13
3635 5594 1002 5632 5482 1261 4193 5812 5608 4188 5900 4749 4941 4468 5074 5132 3581 3600 5651 6023 5840 3329 1746 6177 5332 1648 4189 2415 5536 4026 3091 2974 1311 5848 4910 4240 4701 4080 4516 5582 5004 1771 832 5828 |
#14
Done.
Out: 3635 and 5594 In: 5608 and 4749 Scores should be final. |
#15
Well, there goes THAT plan.
http://www.firstinspires.org/robotic...ip-lineup-show Given that we won't know divisions until Friday... I think we're going to need some planning. CMP starts Wednesday, but NOBODY wants to draft then. Travel, opening the pits, you get the idea. That leaves Friday right after divisions finish announcing (yeah, right--8:30 Eastern at a guess, with no time for a picklist), Saturday, Sunday, Monday, and Tuesday (when folks are packing/traveling, so it's lousy). Guess what that means? THREE-A-DAYs.Well... Maybe not. I should going to be able to run a draft every night except maybe Saturday. But, if y'all don't object, I can probably sneak a Saturday afternoon/evening draft in (as in, probably about 5 PM Eastern or a bit before). And, the draft schedule ain't changin'. So other than the times for a Saturday afternoon-ish draft, I can post all the subdivisions I'll be running at once (less team list) and when they'll be active. If someone else can take a draft each day, we should be A-OK. Add to that that I'm fairly confident I can run two drafts at once if need be... So, short version: I'll post 4 draft orders for 4 of the subdivisions later this week. Pick all at once or one at a time, your choice, once the division lists are out. If someone can handle the second draft each day, great; if not, let's hope the posted orders go quickly... |
