Go to Post wonder if the April peak for 'frisbee launcher' was from the GDC... - cbudrecki [more]
Unread 05-04-2016, 21:08
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
TapeMeasure Climber Dropping after Match End
We are attempting a tape measure climber system for our regional this week. We are essentially using two 775 pro motors to extend and retract the tape measure. (we are using the tape measure itself to climb).
One major problem we are having is staying up, after the match ends and the power is cut. The weight is too much for the 775 pros and the gearing to hold with no power, and the bot quickly slides back down. What are possible solutions to remedy this?
Thanks in advance
Unread 05-04-2016, 21:09
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: TapeMeasure Climber Dropping after Match End
Passive hooks roughly on where your robot wants to stop.
Academic Student (Forever)
Unread 05-04-2016, 21:11
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Could you elaborate please. Thanks!
Unread 05-04-2016, 21:20
Clayton Summerall's Avatar
Clayton Summerall Clayton Summerall is offline
FRC #4587 (Jersey Voltage)
Clayton Summerall is on a distinguished road
Could you post pictures of the climber? It could be an easy fix.
Unread 05-04-2016, 21:22
EmileH's Avatar
EmileH EmileH is offline
uses the Talon SRX way too much
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Thanks in advance
Have you considered engaging a ratchet-like mechanism to prevent backdrive after your climber has extended? Or possibly a pneumatic disk brake?
2016-present: High School Student, FRC 1058 PVC Pirates
Unread 05-04-2016, 21:24
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Well we also have to retract once we are extended, so the ratchet would prevent us from doing that....right?
Unread 05-04-2016, 21:30
EmileH's Avatar
AKA: Emile Hamwey
Which is why you would engage the ratchet as you are retracting the climber/going up, preventing motion in the extend direction.
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
I am at home, but I just texted some guys still at the shop to send some pics, i'll post as soon as I get them. But to describe, the tape is rolled onto a wheel (essentially how it is in the inside of a normal tape measure), but we have two 775 pros geared together to roll that wheel in and out so the tape is extended and retracted. The tape is held onto the wheel by a bunch of 3d printed rollers on the outside, applying constant pressure, and guiding the tape in a straight line.
Unread 05-04-2016, 21:56
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Here are some pics: http://imgur.com/a/91JcU
Unread 05-04-2016, 22:04
RoboAlum RoboAlum is offline
Mickey D's
FRC #4841 (Optimal Robotics)
RoboAlum is a jewel in the roughRoboAlum is a jewel in the roughRoboAlum is a jewel in the roughRoboAlum is a jewel in the rough
Easiest thing to do is the passive hooks we used for our tape measure climber it's a lot like a gate latch. But since then we just use a ratchet system
Co-Founder and Director
RASA (Robotics.Alliance.of Southern Arizona) 501c3
FRC 4841 2013-
VEX 4874 2013-
Student
FRC 71 2010-2013
Unread 05-04-2016, 22:06
CalTran's Avatar
Missouri S&T Senior
Not the greatest example, and I'm having trouble finding examples from this year, but something like the black hooks on 1986's Kraken from 2013. The concept, for instance, would be something like outside flat angled hooks that would ride over the bar but then catch later on and physically not let your robot fall.
Unread 05-04-2016, 22:10
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Ahh, I see. This can totally work, thanks!
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
i secound the ratcheting mechanism, we have ours attached to a servo, that locks it in.
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 05-04-2016, 22:11
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
What material are you using as the ratchet (is that what its called?...)
Unread 05-04-2016, 22:20
CalTran's Avatar
Missouri S&T Senior
Usually teams cut off half of a ratchet wrench.
