Go to Post Six robots no one has ever heard of playing the finals on Einstein field. That's my dream matchup. - Tetraman [more]
Unread 05-04-2016, 22:34
philso philso is offline
FRC #2587
Re: TapeMeasure Climber Dropping after Match End
Originally Posted by CalTran View Post
Usually teams cut off half of a ratchet wrench.
Usually tools are not left in the robot on purpose
Unread 05-04-2016, 22:35
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
And when they are, you either find a random wrench on the field.... or very baaaad things happen.
Unread 05-04-2016, 22:46
FRC #2587
Yes!
We look forward to seeing your robot scale at Lone Star. Safe travels.
Unread 05-04-2016, 22:51
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Yes!
And who knows, we might just do a repeat of last year and alliance up again See you there.
Unread 05-04-2016, 23:35
FRC #2587
And we get past Semi's this time?
Unread 06-04-2016, 10:10
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
We're braking our tape-measure lift with a piece of rubber tubing attached to a Firgelli linear servo. We're using a WCP DS gearbox, so we have easy access to the gearing. The servo just pokes the rubber tubing into the mesh of one of the gears. The only annoying thing is we currently can't leave it engaged during the lift because during retraction it gets sucked into a different mesh and pulled off.
Still, if you can identify a mesh inside that toughbox nano that you could jam with a piece of tubing, you might be able to cut an access hole in the side and do something similar.
I've got a second linear servo coming in today or tomorrow because someone (Joshua Bryant) slightly broke our original, and it's been acting mildly flakey. I could give you the mildly flakey one, but it'd be mildly flakey.
Unread 06-04-2016, 11:49
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
What material are you using as the ratchet (is that what its called?...)
We had these solid steel ring hanging around that we cut off our gearboxes every year. We machined ratcheting slots into this and attached it directly onto the shaft In which the winch pullies are on. Then we attached a servo to a piece of metal so that when the winch is pulling down the ratchet rides over the servo but when it goes up just a second the ratchet locks in. The spring is simply to prevent the robot from falling if power is cut to the servo for any reason specifically the end of the match and we didn't fully climb the spring overrides the servo and locks the ratchet
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 06-04-2016, 12:26
Cam_Team 2619's Avatar
Cam_Team 2619 Cam_Team 2619 is offline
Director/King of The Mill
FRC #2619 (The Charge)
Cam_Team 2619 is an unknown quantity at this point
If you would like some help with a pneumatic disc brake, our team used one to stop our lift from backdriving last year, and therefore I have a fairly good understanding of how it works.
2014 - King of The Mill
2015 - Mechanical Co-Lead/Human Player Backup
2016 - Mechanical Lead
2017 - Director
Unread 07-04-2016, 03:26
PeeDiddy PeeDiddy is offline
FRC #3863 (Pantherbotics)
Team Role: Driver
PeeDiddy is an unknown quantity at this point
A simple way to eliminate back drive would be to toss a worm gear (looks like twisty pasta) in the gearbox.
