Go to Post I'm about to brain myself on a wall in frustration! - pfreivald [more]
Unread 06-04-2016, 12:24
Ky0t3's Avatar
Ky0t3 Ky0t3 is offline
AKA: Wiley Jordan
FRC #5178 (Nerdy Birds)
Team Role: Electrical
Ky0t3 is an unknown quantity at this point
Wrong colour spark
One of our SPARK controllers blinks a yellowish green at idle instead of blue. Does anybody know why it would be doing this? Everything else works perfectly and the LED shows the right colour the rest of the time. We were just really curious and couldn't figure it out.
Unread 06-04-2016, 12:42
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Wrong colour spark
The LED blinks blue in break mode and yellowish in coast mode.
You can set it one way or the other by pressing the mode button on the controller.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 06-04-2016, 12:44
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Hi Wiley,
Your yellow blinking SPARK is probably in Coast Mode. The others are in Brake Mode.
Press the Mode Button once with a straightened paperclip to switch between the modes.
More info can be found in the SPARK User's Manual found here: www.revrobotics.com/SPARK
David Yanoshak
Co-founder REV Robotics | www.revrobotics.com
Unread 06-04-2016, 22:54
Ky0t3's Avatar
AKA: Wiley Jordan
I completely forgot about coast mode! Thanks so much for the help!
