Go to Post I think this is the forest that ChiefDelphi often misses as we're picking the branches off every tree. - Libby K [more]
Unread 06-04-2016, 13:10
Chris is me's Avatar
AKA: Pinecone
Re: Are Fans Pneumatic Devices?
Originally Posted by Scott Kozutsky View Post
This is also the first year pneumatic tires have been "legal" without the rest of the pneumatic control system, as there is now a specific exemption. No one cared in previous years despite being illegal by the rigid, literal interpretation of the rules. W tread Versawheels are illegal per R6 but noone will call that either.
Specific exemptions for pneumatic wheels have been listed in the rules before. Off the top of my head, they were in 2012, but also other years.
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Originally Posted by JesseK View Post
Using some of the definitions in the other thread, every robot on the field uses a pneumatic device to get around: the drive train (hereafter known as "device"). It sounds crazy, but hear me out!
Motors propel the device in such a way to create a high-pressure side and a low pressure side, wherein air on the high pressure side imparts a non-trivial force onto the robot and the surrounding objects. Conversely, high-speed robots can use this device to intentionally create a higher-than-normal pressure situation on the leading edge of the device, which could then be used as an interference mechanism for any lightweight objects nearby - objects comprising of but not limited to:
  • 4060's latching mechanism
  • Paper airplanes on Einstein
  • The hair that belongs to referees
So you're saying we can make the hovervan? Please tell me we can make the hovervan.
Unread 06-04-2016, 13:13
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
We can make the Hover Van.
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 06-04-2016, 13:14
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
You kid... Hmm. What is the theoretical maximum force that high-strength propellers can impart within a 30"x30" frame? Would probably be 12" propellers for a competitive robot, given the probable frame needs. Was never very good with fluid dynamics. I wonder if they could lift 20 lbs up about 30 inches in 10 seconds using our battery.
Then we would add a shell in the shape of a van to the top of the device. And yes, you would get your hovervan, paint job and all
GitHub
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
As I recall, if your pneumatic systems remain under a certain pressure you don't need any lisence or regulation for safety
Rule?
I don't follow?
Originally Posted by R6
Traction devices must not have surface features such as metal, sandpaper, hard plastic studs, cleats, hook-loop fasteners, or similar attachments that could damage the ARENA. Traction devices include all parts of the ROBOT that are designed to transmit any propulsive and/or braking forces between the ROBOT and FIELD carpet.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 06-04-2016, 13:15
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
If a team is really really bad does that make them a pneumatic device because they suck?
Unread 06-04-2016, 13:16
bkahl's Avatar
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
You must spread some Reputation around before giving it to notmattlythgoe again.
Team 125
Team 195
Alumni
Facebook
EWCP
Unread 06-04-2016, 13:17
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Serious question....
The fan is not a pneumatic device
but the tube being filled with air is
right?
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 06-04-2016, 13:18
Flywheel Police
right?
No. The pressure would be too low and if the fan is turned off the pressure is lost.
Unread 06-04-2016, 13:19
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Yes.
Source: we suck so much were not even making elims this weekend
Unread 06-04-2016, 13:20
Flywheel Police
Originally Posted by PayneTrain View Post
Yes.
FRC422 The Mech Tech Pneumatic Devices
Unread 06-04-2016, 13:22
Robotics Engineer
Yes.
PayneTrain's Avatar
AKA: Lizard King
Team Role: Mascot
You think that would fit in the prematch screen?
Unread 06-04-2016, 13:23
Data Nerd
FRC #0079
This thread blows...
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Obviously fans are pneumatic devices. The definition of pneumatic is of or relating to air, gases, or wind.
The definition of fans is any device for producing a current of air by the movement of a broad surface or a number of such surfaces.
I see a relation.
/sarcasm
