Go to Post [in best Tom Hanks voice] Are you crying? ARE YOU CRYING? There's no crying! THERE'S NO CRYING IN ROBOTICS! - dlavery [more]
Thread Tools Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
  #61   Spotlight this post!
Unread 10-03-2016, 00:19
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: Tower Tracker 1.0
Originally Posted by alexpell00 View Post
Thanks for the code, really helped! If anyone is having trouble with the thresh holds you can take the HSV image to http://html-color-codes.info/colors-from-image/ to pull the hex colors of the target. Once you have 3-5 hex colors simply convert them to bgr and find the range from high to low (add/subtract 10% on either end to make it work better).
Yay! Glad it helped! Any link to your code to find how its implemented?
Honestly, my team just used grip to find the values, its easy to use and with the sliders.
  #62   Spotlight this post!
Unread 13-03-2016, 13:44
Happy Birthday! Zaque Zaque is offline
FF: Bobo Brigade
AKA: Zachary H.
FRC #3352 (Flaming Monkeys)
Zaque has a spectacular aura aboutZaque has a spectacular aura aboutZaque has a spectacular aura about
First, thanks for posting this. We have been struggling with vision code for some time now. However, I am having difficulty figuring out how to install the networktables. I can't figure out how to find the correct files and download them by following the instructions on this page.
Thanks again for all these resources!
Zaque (Zach) H.
President
Programming/Electrical Lead
  #63   Spotlight this post!
Unread 13-03-2016, 23:52
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
Just wanted to post and say we ran a modified version of TowerTracker on a Jetson TK1 at the Greater Kansas City regional this weekend with great success. Thank you Fauge and team 3019 for sharing your work.
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
  #64   Spotlight this post!
Unread 14-03-2016, 23:06
Head programmer
No problem, Even if my team got last im proud to say that a team got to the finals with it Congrats one being able to use it succesfully!
  #65   Spotlight this post!
Unread 28-03-2016, 04:32
Head programmer
Tower tracker is now award winning! Shout out to team 1806 Swat! Congrats on going 15-0 at this week's regional! Proof the program can change robots. If anybody needs help with implementing it I am more then happy to help. Pm me with questions.
  #66   Spotlight this post!
Unread 31-03-2016, 14:15
alexpell00 alexpell00 is offline
FRC #2972
alexpell00 is an unknown quantity at this point
Hello. We are having trouble running it on a raspberry Pi. We I try to run the exported jar I get an no opencv_java310 in Java.library.path. Would love to be able to use it for this regions just having some trouble getting it to work. Opencv 310 is installed and compiled on the Pi.
  #67   Spotlight this post!
Unread 31-03-2016, 15:55
axton900's Avatar
axton900 axton900 is offline
Programming Co-Captain
FRC #1403 (Cougar Robotics)
Rookie Year: 2015
axton900 has a spectacular aura aboutaxton900 has a spectacular aura aboutaxton900 has a spectacular aura about
Hey!
when you are building the java file, make sure to include the opencv jar file in your class path. An easy way to do this is to using the -cp command while building.
Doing this will work:
java -cp /home/pi/opencv/build/bin/opencv-310.jar TowerTracker.jar
This configures the class path to include the jar for OpenCV which is the error that you are facing. /home/pi/opencv/build/bin is the default location for the jar.
If you need any more help with this.
Feel free to PM me!
I went through this same process last week
  #68   Spotlight this post!
Unread 06-04-2016, 18:38
axton900's Avatar
Rookie Year: 2015
Hey guys!
How do you calibrate the camera, exactly...
I have opened up GRIP and got the RGB values of a setup in which the goal is clear and then took those values and edited the Lower and Upper bounds respectively but have been getting 0 contours..
Thanks!
  #69   Spotlight this post!
Unread 06-04-2016, 18:41
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Originally Posted by axton900 View Post
Hey guys!
Thanks!
Do you have a link to your code? Also you might want to check that the lower and upper bounds are in BGR order instead of RGB. It took me a while to figure that out.
  #70   Spotlight this post!
Unread 06-04-2016, 19:11
axton900's Avatar
Rookie Year: 2015
I am using an untouched version of TowerTracker and I found RGB values on GRIP and I put them as the Upper and Lower Bounds in BGR order and I still am detecting nothing. Any suggestions? Thanks!
  #71   Spotlight this post!
Unread 06-04-2016, 19:14
jreneew2's Avatar
AKA: Drew Williams
Can you use imshow to display a window of what your original, resize, and threshold Mat's look like? That might help.
  #72   Spotlight this post!
Unread 06-04-2016, 19:20
axton900's Avatar
Rookie Year: 2015
I am not sure how to do so. I am running the Java code provided. I remember your team discussing this on another thread. How exactly do you guys calibrate because that seems to be the problem.
Thanks!
  #73   Spotlight this post!
Unread 06-04-2016, 19:29
jreneew2's Avatar
AKA: Drew Williams
To calibrate the camera, what we did was save the first image it grabbed and then downloaded it onto our pc. Then we brought it into GRIP and found the right RGB values. Then we just plugged it into lower and upper bounds arguments. It worked for us. We did have an issue where we had a really bright image right when the camera started. My best guess is because the camera lens is still adjusting its white balance or something like that. But when just ran the code again after the camera was on for a second. This wasn't a problem in competition because your robot is on a while before the match starts.
  #74   Spotlight this post!
Unread 06-04-2016, 19:32
axton900's Avatar
Rookie Year: 2015
Elaborate on the finding the perfect RGB values. Would you find these to be good?
  #75   Spotlight this post!
Unread 06-04-2016, 19:33
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
I would actually recommend doing your calibration in the HSB/HSV color space, as it separates color(H) from brightness(B/V) which means you can get a more robust calibration that will working in many different lighting environments (as the color your LEDs output shouldn't change) provided you turn your camera's exposure down.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
