Originally Posted by Harrison.Smith
(which was heavily tested and implemented for Dallas). That happened 3 straight matches (new motors every match) and led to our early exit from the elims.
It is probably reasonably quick to change gearboxes/motors over if your using VP's. However because 775pro's are such a precious resource this season, with the supply issues it can't exactly be practical to be going through them at that rate
Originally Posted by MaGiC_PiKaChU
my point, exactly. 4 775's at 16ft second has 4 times less torque than our setup, at 8 775's. Having more torque makes sure you don't stall the motors and burn them. We also learned it the hard way
Have you had any issues with the carrier plates of the gearbox or any other issues with them?
The load rating data sheet, says that the big reduction(7,9,10:1) carrier plates says that they can withstand up to 100 N-m, so your not to close to that, but there are a lot of different stresses in a drivetrain. I suppose part of the reasoning for having the sprocket reduction after the planetary reduction stage was to reduce the torque on the gearbox?
Also how often do you grease the gearboxes?
Sponsors, parents, students and mentors love helping teams succeed. Denso Throttle motors also want to help, don't break their hearts.
REDBOX(gearbox for the throttle motor)
Facebook
