Originally Posted by michaelyork
Is there anything in the program that I could possibly do to alleviate having to disassemble our drivetrain tomorrow?
If you are using Toughbox Mini's and can get you hands on two 14tooth 3/8 hex bore Andymark gears and two 50 tooth 1/2 hex bore Andymark gears. You'll be able to change the gear ratio from 10.71 to 12.75:1 which should improve things, this takes about 15-20 minutes to do each gearbox. At the same time, you can also add the extra CIM motor on each side. It should take about 30 minutes maximium to do this. You can put the CIM pinions on the motors before the event, and then count this towards your withholding allowance, as it will save you some time.
Sponsors, parents, students and mentors love helping teams succeed. Denso Throttle motors also want to help, don't break their hearts.
REDBOX(gearbox for the throttle motor)
Facebook
