Go to Post A robot that does 60% of the tasks 100% of the time is better than a robot that does 100% of the tasks 60% of the time. - artdutra04 [more]
Unread 07-04-2016, 02:17
dardeshna's Avatar
dardeshna dardeshna is offline
Build Captain
AKA: Devin Ardeshna
FRC #0008 (Paly Robotics | Team 8)
Rookie Year: 2015
dardeshna is an unknown quantity at this point
Battery connected backwards to robot
So in the rush to get ready for SVR this week, I wired the leads on one of our batteries backwards. I didn't notice and no one else noticed, so when we plugged it in apparently our breaker made a clicking noise and may have tripped at some point. Regardless, it was left plugged in backwards and on for roughly 10 seconds.
The bad part - the damage. Apparently our VRM is shot, our PCM may be nonfunctional, and our PDP only supplies power to certain rails. Is this a problem that someone else has ran into and had to fix? Or are we just out of luck?
Cheers,
Devin Ardeshna (FRC Team 8)
Unread 07-04-2016, 07:03
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Battery connected backwards to robot
Sounds like you need to start replacing components. Unfortunately, those components aren't really designed to handle reverse voltage.
2016: Lake Superior WFFA
Unread 07-04-2016, 07:20
Interestingly, none of these are the failures I would expect.
The VRM is reverse polarity protected. The PCM is not as explicit in the documentation, but I thought it was as well.
The PDP outputs are just copper, to damage it like that you have described, you would have had to fry the traces off the board. Are you sure it isn't the devices attached to those rails that are damaged?
Your motor controllers are the most likely to be damaged by a reverse polarity event.
Unread 07-04-2016, 07:51
Devin,
To check the output of the PDP disconnect all your loads and try a known good device connected to each output. As pointed out above, there is nothing in the distro that can go bad. However, there is a lot of electronics in the PDP that will be affected by reverse polarity. My suggestion (I know you don't want to hear this) is recycle everything. If it isn't bad now it will fail when you need it the most. The clicking you heard is the resettable breakers.
Unread 07-04-2016, 08:35
anushad anushad is offline
FRC #2876
anushad is an unknown quantity at this point
Are you sure your PDP is shot? Talons/motor controllers burn out super easily; I would check those before replacing the PDP, as it's a pretty nice piece of equipment that is well protected. I wouldn't be surprised if your VRM and PCM needed to be scrapped though; sorry about that.
Unread 07-04-2016, 09:30
I'm wondering how common this mistake is, and if other teams have implemented a process change as a result.
Unread 07-04-2016, 09:47
brunoUC's Avatar
brunoUC brunoUC is offline
AKA: Bruno Toso
FRC #1156 (Under Control)
brunoUC is an unknown quantity at this point
Hello! have you checked the 20A and 10A fuse on the PDP? we had a similar issue and it was a bad fuse.
Unread 07-04-2016, 10:47
ctt956 ctt956 is online now
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Devin,
You could also test the outputs with a multimeter.
In addition to those, I would recommend checking all of the fuses on the robot.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 07-04-2016, 11:12
I know it's prohibitively difficult to put reverse voltage protection on the PDP input. But what about adding an inexpensive (~$2) 70dB buzzer with a diode so that it screams when you apply power backwards? That might give the user a chance to open the breaker quickly enough to avoid frying everything.
Unread 07-04-2016, 11:35
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Ever since we fried a D-link in my first year as a Mentor, all the dlink/camera connections are tested for polarity and voltage before first use.
Similarly, a few years ago, our team acquired a Battery Beak to test batteries before use. It has the added feature of testing for polarity. When a battery is first wired, we use the Battery Beak to test for correct polarity.
http://www.andymark.com/product-p/am-0995.htm
Unread 07-04-2016, 11:37
Ideally, you put it on the Main Breaker, so it screams before you close the breaker and complete the power connection.
Unread 07-04-2016, 13:01
That only protects against a backwards-wired battery. I'm suggesting something built in to the PDP, which would detect any polarity swaps from the battery through the SB-50 connectors all the way to the PDP input itself. I imagine it could be added to the "smart module" with the CAN connectors.
Unread 07-04-2016, 13:59
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
I deal with a lot of robots each year (about 240 this year after this weekend (though probably only 160 unique teams), and I have not seen this on the battery before that I can recall. That obviously doesn't mean it never happens, but I would say it is not that frequent.
I do/did see frequently where leads get mixed up on motor controllers for the inputs. This was much more prevalent with the old victors/talons than the new ones. This would burn out certain controllers. Most often this occurred during a rushed add or wiring job. One team had burned up the current and spare before having me take a look at their robot.
It is pretty easy to make an SB50 connector with an LED and resistor in it. Attached to the battery correctly wired and it will light.
Unread 07-04-2016, 21:34
DonRotolo's Avatar
Back to humble
FRC #0832
I think most of he vulnerable items would fry at nearly the speed of light; realistically too quickly for a reaction to help.
A big honkin' diode across the inputs - reverse biased normally - would act like a short in a RP situation and perhaps trip the main breaker while dropping the voltage to a less harmful level. Needs to handle several hundred Amps for many milliseconds.
