Go to Post (middle school age) One time I had a truly awful day at school and came home crying. My mother's response? "Do you want to go to the build session tonight? It will make you feel better.." And it did. It always does. - rachelholladay [more]
Unread 04-05-2016, 07:52 PM
AMendenhall AMendenhall is offline
FRC #3925
AMendenhall is an unknown quantity at this point
RoboRIO Imaging Fail
We are reimaging a roboRIO which has worked for the entire season.
After testing with and without internet connection, with both USB and ethernet connection to the roboRIO, and with the verified correct image version (v19), we cannot resolve this error:
Unable to download image to target. Unable to complete operation because of unexpected error:nisyscfg.lvlib:Format 5.3.vi:2890001<APPEND>
<b>Complete call chain:</b>
RoboRIOImagingTool.lvlib:Reconfig Device.vi
RoboRIOImagingTool.lvlib:ImageManager.vi
RoboRIOImagingTool.lvlib:ImagingToolMain.vi
I guess Windows 7 doesn't support html tags in it's error dialogues
Unread 04-06-2016, 12:04 AM
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: RoboRIO Imaging Fail
Usually thats due to you powering down the robot while flashing firmware or image...
you can try booting it in safe mode and imaging it from there but if u get a "software error" message in the webdash than you may have bricked it
Unread 04-06-2016, 12:57 AM
ATannahill ATannahill is offline
AKA: Alex Tannahill
If this is the case I would suggest getting NI on the phone. They have ways to turn pieces of clay back into functioning electronics that are not available to teams or even CSAs.
Unread 04-06-2016, 07:56 PM
FRC #3925
Thanks for the quick replies.
I talked with National Instruments today, I was given an extension to use tomorrow, when a different associate would be there.
If worst comes to worst, I'll take it to the booth they have at worlds.
Unread 04-06-2016, 10:45 PM
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Originally Posted by rtfgnow View Post
even CSAs.
With wise choice. If we had access than I'd probably forsee some CSAs (myself...... included? ) following the mindset of "Auton not driving far enough? Reinstall the FPGA on the RIO. Fixed!"
Unread 04-07-2016, 10:19 AM
granjef3's Avatar
granjef3 granjef3 is offline
Code Ninja
AKA: Matt
FRC #2383 (Ninjineers)
Rookie Year: 2016
granjef3 is an unknown quantity at this point
Same thing happened to us when flashing a roborio and it lost power during the process. NI has a process to unbrick using a usb stick to flash firmware, if you call they will help you out.
