Go to Post Most of all, I long to give others a chance to experience what I did with FIRST, to give people from my home town that opportunity, because FIRST really is that once in a lifetime opportunity that so many people dont get a chance to be a part of. It shouldnt be that way. - Jacqui Sutton [more]
  #91   Spotlight this post!
Unread 06-04-2016, 18:25
EmileH's Avatar
EmileH EmileH is offline
#dontbelarge
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Re: Are Fans Pneumatic Devices?
Originally Posted by Woolly View Post
Is mayonnaise a pneumatic device?
For those who don't get the joke
2016-present: High School Student, FRC 1058 PVC Pirates
  #92   Spotlight this post!
Unread 06-04-2016, 18:45
Joining the 900 Meme Team
FRC #0079
Originally Posted by EmileH View Post
Is Spongebob a pneumatic device?
  #93   Spotlight this post!
Unread 07-04-2016, 00:13
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by rsisk View Post
Serious question....
The fan is not a pneumatic device
but the tube being filled with air is
right?
Originally Posted by notmattlythgoe View Post
No. The pressure would be too low and if the fan is turned off the pressure is lost.
My router died, so I've been offline for about a day, which is probably for the best. To amplify a bit on my last post in the other thread, I said essentially that I shall assume that the manuals are written in American English except where the GDC defines otherwise. This is exactly what I meant; when a word means something different in the US than abroad, the folks on the GDC meant the US description (e.g. gas torch means a device which projects flame powered by gas, not a gas lamp). The GDC regularly re-defines terms through the glossary and inline definitions (examples: those things on the front and back of my car are not BUMPERS, and the BATTER is not someone who bats, nor a substance which is beaten, nor a really high slope area around a tower used to redirect dropped items horizontally, but the low-slope area around the TOWER on an FRC field).
Pneumatic (leaving out descriptions of people) generally means "containing or working by compressed air". The game manual expressly excludes (via R77L) pneumatic tires (which usually do not do work beyond acting as springs), vacuum-producing devices (which can be argued as non-pneumatic according to the general definition as they work on the difference between ambient and rarefied air), and closed-loop shocks (which act as springs) as pneumatic devices. It does not expressly exclude fans, radial flow pumps, axial flow pumps, gravity pumps, or impedance pumps. If any of these devices create compressed air that does work (and there is no minimum PSI limit defined by the GDC for compressed air), then by the normal definition of pneumatic in the English language, I consider them to be pneumatic devices -- until and unless the GDC rules otherwise.
For the record - I am not trying to tear down any team that is using fans as pneumatic devices, just giving a warning that until/unless you get a solid ruling from the GDC that what you are doing is somehow an exception to the pneumatics rules, you may find your creative solution shut down at your next event.
  #94   Spotlight this post!
Unread 07-04-2016, 02:46
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Originally Posted by who716 View Post
I'm all for it I don't see anything at all in the rules that would hint at it being illegal in anyway, and on top of it passed inspection once and will most likely pass inspection again if it goes to another event. A+ for the creativity aspect to it
Unfortunately despite their great showing at Auburn thanks in part to their scaling device in question, they did not qualify for the PNW DCMP and have thus ended their season
Originally Posted by CalTran View Post
Passing inspection at one place doesn't necessarily mean it'll pass again. You'd be surprised at what slips through the cracks.
Yes you would be surprised what slips by just for example at inspections at the PNW DCMP this evening a more observant inspector noticed a RS540 motor on a robot that had passed inspection 3 times this season.
However in this case more than one inspector including the LRI at the Auburn event took a look at their wind sock and we all agreed that it was legal and it certainly would have passed had they moved on to DCMP.
  #95   Spotlight this post!
Unread 07-04-2016, 09:16
Chris is me's Avatar
AKA: Pinecone
You're not really addressing the points people are bringing up here - "compressed air that does work" isn't really being created here. Air isn't being compressed - it's flowing. This air is pushing outward as it is flowing through a somewhat constricted opening, but it is not really being compressed. If you are really saying "there is no minimum PSI limit" and that literally any change in air pressure constitutes a pneumatic device, then this would apply to any fan (including those integral to motors / speed controllers), spoked wheel (flywheel shooters move a LOT of air around), etc. Such an absolutist position is just ridiculous.
  #96   Spotlight this post!
Unread 07-04-2016, 09:57
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
If the whole robot drives into a tube with a flap at the other end, it would, for a split second increase the air pressure in the tube.
So is the whole robot a pneumatic device?
  #97   Spotlight this post!
Unread 07-04-2016, 12:56
TheModMaster8's Avatar
TheModMaster8 TheModMaster8 is offline
Active Alumni
FRC #5492 (Robo Jockeys)
TheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the rough
Originally Posted by bkahl View Post
Are 775's Pneumatic Devices?
Their fans move air!
Your robot moves air as it drives.
2009-2011: (FLL) Robot Builder / Operator
2012: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2013: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2014: (FRC Team 2783) Fabrication Student Lead / HumanPlayer / FLL Ref
2015: (FRC Team 2783) Fab Student, Teacher / HumanPlayer / Backup Driver / FLL Ref / FLL Mentor of 6 Teams
2016: (FRC Team 5492) Fabrication Student Lead / Driver / FLL Mentor of Crestwood Elementary
Past Alliance:(2783, 1208, 4154)(2783, 1002, 4265)(2783, 1182, 3868)(2783, 451, 4028)(2783, 1208!, 1288)(5492, 63, 1014) I Will Never Forget
  #98   Spotlight this post!
Unread 07-04-2016, 14:24
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
*Trigger warning, may include some satire/sarcasm
I don't really see any issue with the fan. Now the wind bag (what I like to call the device catching said air) may be a different story. Can someone ask the GDC if Wind Bags are legal? I don't have direct access via Q&A. Here is some sample wording:
On CD, I came across a lot of posts about Fans and Wind Bags. While fans seem perfectly legal, wouldn't the Wind Bags referenced on CD be illegal? With all the attention they are getting, I am afraid that those that follow CD might cause the Wind Bags to multiply. It could get bad enough that most teams at the championship might have a Wind Bag. If wind Bags are legal, then carry on...**
*Just so anyone that is not a regular know this is mostly sarcastic
**Added so that anyone reading this post realizes that this post is mostly satire.
Last edited by IKE : 07-04-2016 at 14:27. Reason: Trigger warnings and satirical disclaimer
  #99   Spotlight this post!
Unread 07-04-2016, 14:51
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
As a windbag myself, I resemble that remark.
Former Mentor Team 1771
Former mentor Team 4509
  #100   Spotlight this post!
Unread 07-04-2016, 14:53
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
Who needs a bag of winds? Just use David Hasselhoff as your human player.
  #101   Spotlight this post!
Unread 07-04-2016, 14:54
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
I only see an issue with mentor-built wind bags... but then I don't know of any other varieties.
  #102   Spotlight this post!
Unread 07-04-2016, 14:56
JohnFogarty's Avatar
AKA: @doctorfogarty
Does it look like a windbag to a reasonably astute observer?
John Fogarty
  #103   Spotlight this post!
Unread 07-04-2016, 15:00
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
The air pressure in your typical latex balloon is [ambient air pressure]+0.005 atm. Convert that to PSI.
**pours gasoline**
  #104   Spotlight this post!
Unread 07-04-2016, 15:26
AKA: Pinecone
**pours gasoline**
Well, gauge pressure in FRC is pressure above atmospheric, so you just need to convert .005 atm to PSI. That is, .073 PSI.
And the pressure in a balloon is significantly higher than a wind sock, since pressure stored in a balloon is actually stretching the latex of the balloon out, where a windsock is just stiffening / taking shape.
  #105   Spotlight this post!
Unread 07-04-2016, 16:15
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Everybody seems to be missing the real question. Is the windbag rated for 125PSI?
