Re: Pocketing
And this would be done through laser cutting? How would CNC or Waterjetting work for this? Is this the same process for box-tubing? Would you be able tp waterjet box tubing?
Re: Pocketing
CNC Milling, Water Jet Cutting, Laser/Plasma Cutting, CNC routing... all would work for this application. CNC Milling would be the best process IMO for box tubing, while you can cut box tubing on a water jet most often you have to use a piece of sacrificial material inside the tube to prevent the jet from cutting both sides at once. The top side will cut clean without the material inside, but the bottom will not come out as desired.
Last edited by Dave McLaughlin : 07-04-2016 at 18:13. Reason: I accidentally a word. |
Re: Pocketing
Re: Pocketing
Depends on the thickness, but usually yes. We've cut 4x4 box tubing on a water jet using wood as sacrifice. The largest inconveniences end up being cutting the sacrifice to size to occupy the volume inside the tube, and getting the sacrifice out of the tubing as the wood will often swell up from being in water.
Re: Pocketing
For pocketing in general, I like 973 ramp video. Also just a great resource in general
